wild.blue(at)verizon.net Guest
Posted: Mon Apr 10, 2006 1:04 pm Post subject: props |
Welcome aboard, Norm,
One nice thing about Whirlwind 3-blade props (McCauley hub) is that in the
event of oil pressure loss the prop will go into high pitch, low drag
configuration. OTH, they generate a huge amount of drag in low pitch that
can be a handy brake on approach. Whirlwind does a beautiful overhaul on
V530 blades, too.
Jerry Painter
Wild Blue Aviation
425-876-0865wild.blue(at)verizon.net
http://mysite.verizon.net/res0cs5r/index.html
dsavarese(at)elmore.rr.co Guest
Posted: Mon Apr 10, 2006 1:32 pm Post subject: props |
And the V530 does exactly the same thing should oil pressure be lost. It
goes to coarse/high pitch as well.
Dennis
HawkerPilot2015
Posted: Mon Apr 10, 2006 5:15 pm Post subject: Re: props |
I just hung my prop this weekend after the Whirlwind overhaul. The prop looks incredible! It looks like a different prop and for what they charge, you cant beat it! I HIGHLY recommend having it done if your prop needs a little touch up!
