ulflyer(at)verizon.net Guest
Posted: Sun Sep 20, 2009 2:54 pm Post subject: Grandr Rapids EIS or others. |
Yes Sandy is great person to work with. The fuel probes are of the capacitance type and come in different lengths. When you order them your going to need to know the approx. length you will need. Note, from their original length they may only be cut back to a minimum length and retain the ability to adjust them within the minimum and full calibration range. They work great. Before you error cut mounting holes for them to big be aware that the inside tank mounting ring is made where it can be passed thru a smaller hole than you first think is required. Some string may be used to hold it in position during the installation. They work great.
jerb
At 09:58 PM 9/18/2009, you wrote:
[quote]Your best bet is to call Grand Rapids, you will talk to Sandy who is so knowledgeable that several guys have proposed to her over the phone, including me. She can fix you up with what ever you need. There are several sizes of senders, I used the 12 inch one with my stock tanks.
Larry C
