dsavarese(at)elmore.rr.co Guest
Posted: Sat Apr 08, 2006 7:47 am Post subject: Firewall fuel shut-off (was: Re: glide ratios)Firewall fuel |
Val, it has nothing to do with the engine itself. The mechanism being discussed in part of the Yak 52's coarse fuel screen assembly which is mounted to the firewall. The cable from the fuel shut off handle is connected to an over-center arm on this assembly. From that assembly is a flexible hose that connects to the fuel pump. You would have to look at the CJ's fuel system diagrams to determine if it is the same. My guess is it probably is, but I am not certain. One of the CJ experts probably can say for sure. If we had the cowl off, we could tell in a heartbeat. Hope this helps.
Dennis
