bughntr(at)comcast.net Guest
Posted: Fri Sep 25, 2009 5:00 pm Post subject: Grove Gear Model II |
I am planning on installing grove gear on my model II. I will need to add the float mounting bracket and was looking for any help on how to weld this with minimal fabric damage. Any help would be appreciated.
Bryan Quinton
Model II 582
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sat Sep 26, 2009 7:39 am Post subject: Re: Grove Gear Model II |
Quote: | I am planning on installing grove gear on my model II. I will need to add the float mounting bracket and was looking for any help on how to weld this with minimal fabric damage. Any help would be appreciated.
Bryan, if the finish is Poly tone it is fairly easy to cut out a section of fabric and replace with new. If you have worked with fabric before it will be easy, if you haven't, someone helping that has will be a must and use the repair instructions in the poly fiber manual.
I would use a straight edge and razor blade to cut out a section spanning from the leading edge of the stock front gear mount to about 8 inches forward of the new mount to be welded in. From the bottom of the door frame to about 8 inches in on the belly.
To repair the fabric, poly tack one new piece to the bottom door frame and to the old fabric down and under the belly. No poly tack or wraping around the bottom longeron tube. When you shrink the new piece it will pull the old fabric tight and back into place.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
napierm(at)cisco.com Guest
Posted: Sun Sep 27, 2009 6:17 am Post subject: Grove Gear Model II |
Bryan,
Another method is to "peel" the fabric. If the bottom fabric was put on
1st and then the side you are in luck. You can peel and then re-glue
the fabric and it will look like it had never been touched. I've done a
couple of repairs this way and it does work.
If you want to do this then do not cut the fabric.
Take a thin but not too sharp knife and work the reinforcement tape
loose from the bottom side. A piece of 0.25 aluminum with smoothed
edges can make a pretty good tool for this. In the area you are talking
about you will have to start close to the firewall and work back close
to the main gear mount. The goal is to take the tape loose from the
bottom fabric but don't break it loose from the side fabric and break
the paint on the side.
Once the tape is peeled back you can peel the "side" fabric from the
bottom. The bottom fabric can then be peeled loose from the bottom
tube. This is time consuming but better than having to paint a large
area. You can take another piece of thin aluminum and bend it over to
make a wide "hook" to make it easier to get at the edge of the fabric
wrapped around the tube.
Keep the fabric well back from the welding area and don't let it bend
over too far as the paint can crack.
When you put it all back do it all in reverse. Clean the tubes 1st with
MEK. Try to keep it off the fabric. Reattach the fabric with poly-tak.
Pull it as tight as you can. There will still be some loose spots and
these can be tightened with heat later. Use poly-brush to reattach the
tape.
If done carefully the only visible sign you have done anything is the
break in the paint at the edge of the pinked tape on the bottom of the
fuselage. If you are really careful the break will follow the zig-zag
edge of the tape. The repair is really hard to see.
I know you will have to add some reinforcement tape to account for the
new bracket you are adding, but you may be able to put those tapes
"under" your existing fabric to hide the modification as much as
possible. I haven't been able to get new paint to blend with old very
attractively. Try to preserve the side tape and your touchups will be
under the fuselage.
Hope this helps,
Mark Napier
Time: 08:44:20 AM PST US
Subject: Re: Grove Gear Model II
add the
with
of fabric
easy,
repair
spanning from
of the
inches
in on the belly.
and to the
bottom
fabric
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 65110#265110
Pat Reilly
Posted: Sun Sep 27, 2009 7:38 pm Post subject: Grove Gear Model II |
Bryan, You can also replace the fabric with an aluminum belly pan. I did on my model 3 and figure it added around 3 #. Maybe you don't want the added weight. But, it's just another option.
Pat Reilly
Mod 3 Rebuild
Rockford, IL
On Sun, Sep 27, 2009 at 9:10 AM, Mark Napier (napierm) <napierm(at)cisco.com (napierm(at)cisco.com)> wrote:
[quote]--> Kitfox-List message posted by: "Mark Napier (napierm)" <napierm(at)cisco.com (napierm(at)cisco.com)>
Bryan,
tape.
under the fuselage.
Hope this helps,
Mark Napier
From: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
add the
with
of fabric
easy,
repair
spanning from
of the
inches
in on the belly.
and to the
bottom
fabric
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=265110#265110
Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Posted: Mon Sep 28, 2009 3:52 pm Post subject: Grove Gear Model II |
Pat;
Interesting idea. Do you have a photo that will show me what you have done? Thanks..Bryan
Pat Reilly
Posted: Mon Sep 28, 2009 7:14 pm Post subject: Grove Gear Model II |
Bryan, I don't have any photos of the aluminum belly pan. It was easy for me. I did it in the fusalage covering process. I had the fusalage on a rotisserie so I had the bottom up, cut the sheet to dimenson, laid it on and marked for any cut outs around the brackets. I can't remember the thickness of the sheet I used. I made it in 2 pieces, one fore and one aft. Front one overlapping the rear piece. I folded the edges over to stiffen. I used rivet nuts for 10-24 screws that I attached to the tubing with wraps of adhesive anti chafe tape. Maybe 12 or so per each piece. I know at the time I thought this will never be attached well enough but low and behold something worked better than anticipated for a change. Sorry, I can't be more descripitive, or have pictures for you.
A number of the KFer's poopooed me at the time. But, I have already had the pan off to install Lowell Fitt's bush gear. Had the pan off in 10 minutes and back on in 10 minutes. No worries about recovering. I'd do it again if I was building or rebuilding another KF.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Mon, Sep 28, 2009 at 6:50 PM, <bughntr(at)comcast.net (bughntr(at)comcast.net)> wrote:
Pat;
