Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Tue Apr 11, 2006 6:52 am Post subject: Rain Repellant |
Rick,
I think it's Rainx ... but ... caution, says not to use on plexiglass.
Jerry Grimmonpre'
RV8A
DO NOT ARCHIVE
GRANSCOTT(at)aol.com Guest
Posted: Tue Apr 11, 2006 6:54 am Post subject: Rain Repellant |
In a message dated 4/11/2006 10:01:20 AM Eastern Standard Time, rick.conti(at)boeing.com writes:
| Quote: | | Does anyone know the name of the wind screen rain repellant product? |
That will not break down over time causing rainbows!!! Becareful on a coating product...a number of these products have silicones in them that long term bring headaches.
Patrick
Posted: Tue Apr 11, 2006 6:55 am Post subject: Rain Repellant |
Jerry probably should not be used on glass either...IMHO...
Patrick
Tdawson(at)avidyne.com Guest
Posted: Tue Apr 11, 2006 6:58 am Post subject: Rain Repellant |
A nice mélange of crushed black flies and mayflies works well . . . : )
TDT
40025
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com
Sent: Tuesday, April 11, 2006 10:54 AM
Subject: Re: Rain Repellant
Patrick
rick.conti(at)boeing.com Guest
Posted: Tue Apr 11, 2006 7:08 am Post subject: Rain Repellant |
True, Rain-X should not be used on plexiglass. I believe there is a
product especially for plexiglass. That's what I'm looking for.
Thank You
Rick Conti
office: 703-414-6141
cell: 571-215-6134
rene(at)felker.com Guest
Posted: Tue Apr 11, 2006 7:23 am Post subject: Rain Repellant |
We use Pledge on our Cessnas.....
Rene' Felker
bootless(at)earthlink.net Guest
Posted: Tue Apr 11, 2006 11:57 am Post subject: Rain Repellant |
Are you thinking of RainAway?
AeroShell PlexiCoat works well, too.
best, Cory
Randy(at)abros.com Guest
Posted: Tue Apr 11, 2006 2:42 pm Post subject: Rain Repellant |
I use Plexus on my 10. It is available at all aircraft supply houses and
Van's carries it as well. Randy
Posted: Wed Apr 12, 2006 3:54 am Post subject: Rain Repellant |
Just beware that Pledge has a high amount of alcohol in it plus a good slug of water...it could cause your plexiglass to soften or haze...I know the Pledge trick has been used by a lot of owners but it may not be the best way to clean or keep the windscreen clean...sort of an old wives tale cure...you might contact SC Johnson--they have a phone number on each can--and ask them for their advise on using using Pledge on Plexiglass/planes to see if they've tested it long term.
Patrick
BSchroeder(at)uta.cog.ut. Guest
Posted: Wed Apr 12, 2006 5:34 am Post subject: Rain Repellant |
Motorcycle stores and aircraft suppliers have spray plexi cleaners and polish that are readily available for your windscreens. Also, mcguires makes similar products available at auto body supply store and auto parts stores.
patrick.pulis(at)seagas.c Guest
Posted: Wed Apr 12, 2006 5:37 pm Post subject: Rain Repellant |
Guys, we have been using Plexus on glider canopies here in South Australia for years and they look as good as new and crystal clear all the time.
Patrick
South Australia
DO NOT ARCHIVE
From: Schroeder, Bob (Parts Clerk) [mailto:BSchroeder(at)uta.cog.ut.us]
Sent: Wednesday, 12 April 2006 11:04 PM
Subject: RE: RV10-List: Rain Repellant
-----Original Message-----
Sent: Wednesday, April 12, 2006 5:53 AM
Patrick
