brad(at)mykcwireless.com Guest
Posted: Sun Oct 25, 2009 2:41 pm Post subject: Matco Brake Problem |
I recently bought a Kolb Mark III Classic. It has Matco hydraulic
brakes with toe pedals - the MC-4 master cylinders and the B4 calipers.
Differential, pilot side only. I have a problem with having zero
stopping power. No amount of pressure on the toe pedals will stop the
plane, even at slow taxi speed. It's as if the calipers are not
squeezing the rotors hard enough. Here's what I've done so far -
replaced the master cylinders (brand new), bled the lines, and checked
the toe pedal geometry. I can see the calipers moving when I push on
the pedals, so they're not completely frozen. An A&P looked at it too,
and he's stumped. One thing that's unusual is that the pistons are
really stiff on the master cylinders, and hardly have any travel. It's
really hard to push them down, even with a hand, and I know that's not
normal. Definitely not mushy like when there's air in the lines. I'm
using the red automatic transmission fluid, which I've read is okay.
Has anybody encountered a similar problem with their brakes, and what
did you do about it? I haven't been able to fly my plane yet because of
this, so I'm hoping that I can find a solution. Short of buying new
calipers, I don't know what else to do. Thanks for any suggestions.
Posted: Sun Oct 25, 2009 3:50 pm Post subject: Matco Brake Problem |
Brad
Matco brakes work quite well but take a bunch or pressure to activate them.
The Matco heal brakes that I have work well but take much more pressure than
I would feel comfortable pressing against the rudder cables as you have to
do with the toe activators. It seems like one of our members reworked the
geometry of the toe system to get more hydraulic pressure without stressing
the rudder cables. Note! Matco also makes larger calipers and dual caliper
conversions that might resolve your issues.
It also seems like Dennis Souder (Old Kolb engineer and one time owner) just
talked about this very issue as to why they developed the heal brakes.
Rick Neilsen
Redrive VW powered MKIIIC
bill_joe(at)bellsouth.net Guest
Posted: Sun Oct 25, 2009 5:24 pm Post subject: Matco Brake Problem |
Hi Brad...
I had the same problem kinda but I had Travis make a new set of the toe
pedal to increase the leverage on the master cylinder . Also I called Matco
and they have a new lining that has a lot more stopping power. I had them
send me a new set of the lining and with the new pedals Travis built for me
took care of my break problem. I'm sure Travis has the print I sent him for
the toe peddle.
I will take a couple pictures of the peddles in the morning and send
you. I have a MK1112Xtra912-80hp and the pedals will hold it up to 4500 RPM.
Posted: Sun Oct 25, 2009 6:04 pm Post subject: Matco Brake Problem |
It would be interesting to see what you could read on a pressure gauge.
One point to be made is contact area. New pads frequently don't
present enough to give full effect.
If they are working at all, try jacking one axle, applying full pedal
and hand turning the wheel.
If you get some resistance do some taxi with the brakes on to help
wear them in. The rotors on working
brakes will show a track.
BB
On 25, Oct 2009, at 6:38 PM, Brad Zearfoss wrote:
calipers. Differential, pilot side only. I have a problem with
having zero stopping power. No amount of pressure on the toe pedals
will stop the plane, even at slow taxi speed. It's as if the
calipers are not squeezing the rotors hard enough. Here's what I've
done so far - replaced the master cylinders (brand new), bled the
lines, and checked the toe pedal geometry. I can see the calipers
moving when I push on the pedals, so they're not completely frozen.
An A&P looked at it too, and he's stumped. One thing that's unusual
is that the pistons are really stiff on the master cylinders, and
hardly have any travel. It's really hard to push them down, even
with a hand, and I know that's not normal. Definitely not mushy
like when there's air in the lines. I'm using the red automatic
transmission fluid, which I've read is okay. Has anybody
encountered a similar problem with their brakes, and what did you do
about it? I haven't been able to fly my plane yet because of this,
Thom Riddle
Posted: Mon Oct 26, 2009 4:14 am Post subject: Re: Matco Brake Problem |
My Matco brake documentation says to use 5606 fluid, not ATF fluid. Not sure what kind of seals and o-rings are in Matco brakes nor if the they are compatible with ATF. I use 5606 per Matco's spec.
Matco also states that you need 2.5 to 1 mechanical advantage on the actuator. If your pedal setup does not give you that, the braking power will be diminished proportionally.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Mon Oct 26, 2009 5:22 am Post subject: Matco Brake Problem |
| Quote: | My Matco brake documentation says to use 5606 fluid, not ATF fluid. Not
Thom/Gang:
Have used ATF with MATCO brakes since day one, 1992. Since that time have
gone through three different sets of brakes. Each set an improvement on the
previous set. In fact, I'm still using the same quart of ATF I bought for
my new Hegar brakes I installed on the FS in 1989. Works great for me.
However, if MATCO says 5606 for current model brakes, I'd go with that.
Las Vegas, Nevada
_________________ John Hauck
Titus, Alabama |
by0ung(at)brigham.net Guest
Posted: Mon Oct 26, 2009 7:26 am Post subject: Matco Brake Problem |
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>
The matco paperwork says "o-ring BUNA N " I have only used what is
specified.. not sure if it will be compatible with atf or not.
Boyd Young
JetPilot
Posted: Mon Oct 26, 2009 6:17 pm Post subject: Re: Matco Brake Problem |
| brad(at)mykcwireless.com wrote: |
normal.
Thanks for any suggestions. |
I can almost assure you that this is part of your problem. If the pistons are not moving fairly easily inside the calipers, you will get very little braking power. I have had this several times on various braking systems, and it always has resulted in very poor braking power. Check for corrosion around the rubber ring inside the caliper, it can cause the rubber to be so tight against the piston that it will hardly move. Also deformed piston can cause this, but corrosion is much more common.
Mike
Kolb MK-III Xtra, 912-S |
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Fri Oct 30, 2009 12:12 am Post subject: Re: Matco Brake Problem |
Brad,
Sorry for the late reply.
I don't know if this would help but I'll offer.
I have a set of old Matco brakes, axles, & hubs. I replaced them with the larger axles and brakes when I upgraded my landing gear. I think I have the same set you are referring to.
If you need them for parts, I'd send them your way. Need to get them out of shop. Fair price guarantee!
E-mail direct if interested.
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
