bgill1(at)charter.net Guest
Posted: Tue Apr 11, 2006 2:23 pm Post subject: Door latch covering |
I am in the process of covering my door interior surfaces with material. Does any one have any good photos that you could post or forward of how best to cover the latch mechanism area. I have looked through several builder sites and couldn’t find a photo that showed good detail. Also couldn’t dig up anything in the archives.
My goal is a cover that could be removed for fairly easy access to the mechanism but would make the door panel look clean with out seeing the latching gears.
Any suggestions appreciated.
Byron #40253 finishing kit…
Tim(at)MyRV10.com Guest
Posted: Tue Apr 11, 2006 4:50 pm Post subject: Door latch covering |
I just cut a rectangular cover plate out of aluminum and glued it on
with some E6000 over the latch area, so the fabric would have a smooth
surface under it. I don't know that it would be worth spending too
much time making something that could be removed extremely easily...if
you had to do that, you'd probably be tearing your fabric off anyway.
If that's your goal, I'd make a larger, more decorative cover plate,
and don't put the fabric over the latch area at all.
Byron Gillespie wrote:
| Quote: | I am in the process of covering my door interior surfaces with material.
latching gears.
jesse(at)itecusa.org Guest
Posted: Tue Apr 11, 2006 5:59 pm Post subject: Door latch covering |
You could cover up to and around the match area, and then make a cover plate
that screws or snaps on and cover that separately. See the pictures of the
TruTrak plane. They have something like this, although the whole bottom of
the door is a removeable panel, it looks like.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of
May. You may call me at 352-505-1899 and leave a message that I can check
from down here. Any I-TEC questions can be directed to the I-TEC office at
352-465-4545.
