Starter question
Lew Gallagher
PostPosted: Sun Nov 01, 2009 9:29 am    Post subject: Starter question Reply with quote
Hey Guys,
Here's a quick question. We bought a rebuilt Lycoming IO 540 that came with a starter installed. We're getting close to final assembly and I noticed that the throw-out gear that engages the ring gear seems spring loaded to stay engaged. On cars, this is opposite and retracts after starting. Does this somehow work the same way -- once it fires the gear spins back? Or is it something I should look into? I can get the model of the starter later today if that's necessary. I noticed this after testing the switch/relay/starter circuit by bumping the starter switch with the ring gear off. Thanks.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
deej(at)deej.net
PostPosted: Sun Nov 01, 2009 10:13 am    Post subject: Starter question Reply with quote
Hi Lew,
Once the engine starts the starter gear is disengaged from the starter
ring.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
wcurtis(at)nerv10.com
PostPosted: Sun Nov 01, 2009 10:48 am    Post subject: Starter question Reply with quote
Assuming this is an older aviation starter, what you are looking at is a starter Bendix.  Unlike automotive (and some new aviation) starters, these older starters use a Bendix mechanism that engages when the starter is turned and retracts when starter is disengaged.  When maintained properly, starter Bendix work well enough but solenoids work better.
If that starer is bad, upgrade to a Skytec NL starter with an in-line solenoid.
William
http://wcurtis.nerv10.com/
On Sun, Nov 1, 2009 at 1:29 PM, Lew Gallagher <lewgall(at)charter.net (lewgall(at)charter.net)> wrote:
--> RV10-List message posted by: "Lew Gallagher" <lewgall(at)charter.net (lewgall(at)charter.net)>
Hey Guys,
Later, - Lew
non-pilot
Painting done!
On with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p=270463#270463
ber is the Annual List Fund Raiser.  Click on
-=     * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
nics List Features Navigator to browse
s.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
William
N40237 - http://wcurtis.nerv10.com/
Lew Gallagher
PostPosted: Mon Nov 02, 2009 4:04 pm    Post subject: Re: Starter question Reply with quote
Thanks for the responses DJ and William.
After further research, this is a Kelly Aerospace MZ 4222 starter and the drive gear disengages once the engine reaches 400 rpm. It lists for $1272 new ... wow. Rebuilt $365 w/ $200 core charge.
Probably much heavier than the Skytec starters, but we'll see how it works.
Later, - Lew
non-pilot
Fly off completed !
dlm46007(at)cox.net
PostPosted: Mon Nov 02, 2009 4:23 pm    Post subject: Starter question Reply with quote
You probably ought to plan now to get the correct Skytec as they are less
than half the weight and (IIRC) have no Bendix which requires lubrication
and cleaning. If your current starter is new you may be able to trade to get
the Skytec.
