cknauf
Posted: Tue Nov 03, 2009 8:01 am Post subject: MSP towing |
It's time to move the fuselage to the airport and we're wondering if anyone in the Twin Cities has a flatbed towing company they prefer or who has done this before and understands the attention to detail and special handling required.
Chris Knauf
RV-7, N707HK
Posted: Tue Nov 03, 2009 9:23 am Post subject: MSP towing |
Chris,
I transported mine twice using a fellow pilot's flatbed trailer.
Wings, wheels, and engine mount were not attached. I was told that the engine should not be attached as the road bounces would cause damage. Foam underneath, straps and come-alongs to hold it in place - no issues.
I've got a few pictures - zap me direct....
Ralph
bifft(at)xmission.com Guest
Posted: Tue Nov 03, 2009 10:06 am Post subject: MSP towing |
On Tue, 3 Nov 2009, Ralph E. Capen wrote:
Chris,
Just moved mine to a two-car garage, pictures at:
http://www.xmission.com/~bifft/plane/
went really easy.
Brian Huffaker, DSWL (bifft(at)xmission.com)
RV-8A 80091 organizing new garage.
1/4 Starduster II N23UT flying
baremetl(at)gvtc.com Guest
Posted: Tue Nov 03, 2009 5:53 pm Post subject: MSP towing |
In my case, the engine was attached to the fuselage (along with the entire
empennage, canopy and landing gear) and it made it 30 miles to the airport
on a flat bed trailer. No sign of damage to the engine after 1600 hrs. over
the last 17 years.
Ivan Haecker -4 S. Cen. TX
ghinman(at)mts.net Guest
Posted: Wed Nov 04, 2009 7:20 am Post subject: MSP towing |
I just hooked a trailer hitch to the tail of my
RV-8 and towed it on its own wheels.
The engine was attached,but no empenage or wings.
It worked great.The bearings got a bit hot,but no damage.
required.
Chris Knauf
George H. Inman
ghinman(at)mts.net
ianxbrown
Posted: Wed Nov 04, 2009 7:58 am Post subject: MSP Towing |
FWIW, when I moved my 9A fuselage with engine mounted I used a U-Haul box van. The dimensions are slightly wider than the footprint of the 9A but the doorway is slightly narrower. This meant getting the aircraft up ramps to the almost-in position, and then doing a sideways jog to get the wheel nuts past the door frame. It was a fairly short trip but I had no problem moving it with the engine mounted - either during or after. The engine/prop were sticking out of the open door!
If the mount is designed to withstand a hard landing I assume it's also built to withstand similar stresses on a road trip.
By the way, if you try to do this, the typical U-Haul van comes with only one ramp. I used a ladder with an assortment of boards on it for the other main wheel, and friends to balance the nosewheel to the right angle. A combination of a come-along and people turning the wheels by hand managed to get it up the ramp nicely.
Ian Brown, C-GOHM, Bromont, QC
| Quote: | | Quote: |
From: "Chris Knauf" <cknauf(at)comcast.net (cknauf(at)comcast.net)>
Subject: MSP towing
required.
Chris Knauf
rv9ralph(at)tailsrwaggin. Guest
Posted: Wed Nov 04, 2009 5:04 pm Post subject: MSP towing |
One caution when transporting. One of our chapter members, with a tip-up
RV-6 had it on a flatbed trailer backwards (mains wouldn't fit between the
trailer wheels). The canopy caught the wind and caused considerable damage
to the attach points. Be sure to tape/latch the canopy well.
Ralph
RV9A Livermore CA
Wings
