kitfoxsport(at)verizon.ne Guest
Posted: Wed Nov 11, 2009 12:17 pm Post subject: Positive fuel drain for header tank? |
I know someone once posted a fuel drain that can be used to drain all fuel out through the header tank. I believe it came from Spruce. So first which part number and how long to drain lets say per gallon of fuel?
George
Sport Model - 914- almost, but not yet!
msm_9949(at)yahoo.com Guest
Posted: Wed Nov 11, 2009 3:22 pm Post subject: Positive fuel drain for header tank? |
George,
I simply replaced the AN elbow at the bottom of the header tank with an AN tee fitting. One branch now goes to the engine, other through a shutoff valve to a drain fitting on the belly of the plane. I did reinforce the belly at the drain by backing fabric with a small piece of aluminum, pop-riveted to the fuse-frame. Shut off the main fuel valve, open the header vent and the drain valve (located behind passenger seat) and fuel drains quite quickly (through a detachable hose) into cans. Nothing fancy, works great.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Wed, 11/11/09, Kitfox George <kitfoxsport(at)verizon.net> wrote:
Subject: Positive fuel drain for header tank?
Date: Wednesday, November 11, 2009, 3:02 PM
George
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
llow target=_blank>http://www.matronics.com/contribution
el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-List
et=_blank>http://forums.matronics.com
