AZFlyer
Posted: Wed Oct 07, 2009 11:48 am Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners |
List,
For those using the Jab USA supplied FWF kit:
Has anybody found the "Camloc Fasteners" (10 - Camloc #26S8-6) to be too long for the cowl? Just right? or ?
My cowl thickness seems to be around .150" which would indicate a 26S8-4 or -5.
I may be measuring incorrectly.....?
Thanks for feedback.
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
jfowler120(at)verizon.net Guest
Posted: Wed Oct 07, 2009 12:24 pm Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners |
We have a Jabiru FWF kit of a few years ago. The camlocs vary from # 5 to #6 for reasons I can't explain -- just reality.
Karl Polifka
mhubel
Posted: Wed Oct 07, 2009 12:33 pm Post subject: Re: Firewall Forward Kit from Jab USA/Camloc Fasteners |
I found that the fiberglass thickness was highly variable and there was no one size camloc that would work everywhere. Going just by the measurement may also lead to cams that are somewhat hard to open or almost fall out. I bought a few on each side of ideal and did a best fit to each hole.
I used a range of #4 to #6.
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
zman601xl(at)aol.com Guest
Posted: Thu Oct 08, 2009 4:13 pm Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners |
Mike,
I had a problem wih some of the fasteners(to long).What I did was make up shims,and shimmed each female portion so that the male portion would fit properly(fit flush).It's sort of a pain in the neck but it came out nice.Speaking of the top cowl fit I doubled the number of camlocs on each side.If you go with what they give you you will have" bulges".I've seen quite a few where the top cowl does not fit tight from front to back.It all depends how much time you want to spend.
Bob Haring N107RW
AZFlyer
Posted: Fri Oct 09, 2009 7:31 am Post subject: Re: Firewall Forward Kit from Jab USA/Camloc Fasteners |
Many thanks to all that responded so quickly to my camloc question.
Now back to building.
Thanks again,
a.f.rupp(at)att.net Guest
Posted: Sat Oct 10, 2009 7:49 am Post subject: Firewall Forward Kit from Jab USA/Camloc Fasteners |
Mike,
A rub strip on the cowling can snug up those fasteners also.
Al Rupp
601XL 765AR
Lake Placid, NY
-------------- Original message from "AZFlyer" <millrML(at)aol.com>: --------------
Thanks again,
Mike Miller (at) millrml(at)aol.com
601 XL, 3300, Dynon
http://forums.matronics.com/viewtopic.php?p 67233#267233
pacella
Posted: Sat Nov 14, 2009 1:58 am Post subject: Re: Firewall Forward Kit from Jab USA/Camloc Fasteners |
How do I take a firewall down on limewire or morpheus so I can download again? I have limewire and Morpheus, It is blocking me from downloading because of a firewall (windows possibly). But I stopped the Windows firewall and dont have firewall software. What do i do?
________________________
UK matrimonials
