		bcharvet(at)bellsouth.net Guest
				 Posted: Sun Nov 15, 2009 12:42 pm    Post subject: Certified Engine question |
				I had installed a used Continental A-65 on my recently finished
 project.  In the process of getting ready for my airworthiness
 inspection with the FAA we did a compression test and found one cylinder
 to be low(35/80).  The engine ran great but did have a lot of blow-by.
 Oil pressure was appx 25 at idle and mid 30's above 1200 rpm.  I pulled
 the weak cylinder and found that the #1 rod bearing has excessive wear.
 I mean like you can do the push pull thing and feel slop.  The engine
 came with log books, was 1500 SMOH, but I was hoping to get through
 phase 1 flight testing, since the logbook compressions were all good.
 Basically I understand now the engine needs a total rebuild.
 So here is my question.. I am no an A&P, but have lots of experience
 rebuilding engines of both air cooled and water cooled all in
 automobiles.  I'm confident I can do this myself.  I already had started
 overhauling parts prior to finding this engine and have a rebuilt case,
 crank, and cam.  I've been told that to call my engine a Continental
 A-65 and leave the data plate on, that all this work would need to be
 signed off by an A&P.  I have a certified Sensenich wood prop installed
 and was hoping for a 25 hr Phase 1.  All the paperwork is already sent
 in the the FAA and the inspection is scheduled for Dec 4.  So if I do
 this work myself , do I call it a Ben Charvet 65 HP?  Bet that would
 drive the insurance folks nuts.
 I also have one other option.  I have my trusty old Baby Ace that is in
 bad need of a restoration, but has a 350 SMOH A-75 with a McCaulley
 metal prop (would help my W&B).  I was really hoping to keep flying the
 Baby Ace right up till my first flight in the Piet, but I could just
 swap that engine on, change the paperwork with the FAA, and rebuild the
 A-65 at my convenience while restoring the Baby Ace at some later date.
 I was really hoping to sell the Baby Ace, but its not worth more than
 its engine/prop anyway.
 This is without a doubt the longest post I've ever made, but this is a
 tough choice.
 My main question is:  If  a non-certified mechanic rebuilds a certified
 engine, can you legally leave the data plate on?  Is it still a
 Continental A-65 legally as far as the FAA/Insurance companies are
 concerned?
 Ben Charvet
  |  | - The Matronics Continental-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dsleepy47
				 Posted: Sun Nov 15, 2009 1:51 pm    Post subject: Certified Engine question |
				There is no requirement to remove the data plate or stop calling it a Continental. You actually have several options. If you can find an A&P who will supervise and sign off the work you do you can do that. If you want to perform the work without supervision then you make an engine log entry that it was built or experimental use. "Overhaul" has a specific meaning to the FAA and you should not put that in the log unless you meet the FAA requirements for an overhaul. The requirement for phase 1 is a certified design C the experimental engines and "kits" supplied by the engine manufactures are routinely given the 25 phase 1.
 If anyone tells you the data plate needs to be removed C ask them politely which FAA regulation requires that (there isn't one).
 Deems
 [quote] A-65 and leave the data plate on C that all this work would need to be
  		 	   		  Hotmail: Trusted email with powerful SPAM prote='_new'>Sign up now.
  _________________ dsleepy47
N1491R |
		eclarsen81(at)aol.com Guest
				 Posted: Sun Nov 15, 2009 8:44 pm    Post subject: Certified Engine question |
				Ben,
   As stated in a previous post, leave the tag on, there is no
 requirement to remove it or modify it under the current regulations.
   If to reduce your insurance costs it would benefit you to maintain the
 engine in a certified state, the money would be well spent to find an
 IA and complete the overhaul under his supervision, completing your
 yearly condition inspections with an A&P or P rated mechanic inspecting
 the motor. Should the engine be sold in the future, it could be done so
 as a certified motor.
   Barring that, taking the role on yourself, the next entry after the
 removed from previous aircraft should be that the motor was installed
 on your aircraft, identified for experimental use in accordance with
 (reg). Additional entries should be the repair or overhaul completed,
 again in accordance with (overhaul manual). Include serial numbers,
 work order numbers, and repair stations so that you can reference them
 to future AD's.
 Keeping accurate records adds value to the motor should you sell it in
 the future. As far as AD's, when it is operated and maintained as
 experimental, you have the choice to comply or not.
 Apply for your repairman certificate as well, that should help keep
 insurance lower as well.
 Disclaimer: these are my thoughts and opinions only, your own may vary.
 Good luck.
 Ed
