Zenith701801-List:Re: electric fuel pump behind seat of a 70
ggower_99(at)yahoo.com
PostPosted: Wed Nov 25, 2009 1:01 pm    Post subject: Zenith701801-List:Re: electric fuel pump behind seat of a 70 Reply with quote
Hello Kevin,
Well, is used by pilots here forever... Smile a must for the AG pilots... This is the chamoise that is made from deer skin (?), works like those new micromesh black funnels, make a test.
In a funnel atach a chamoise loose inside so the gasoline will not spill, see how easy will pass trough. then test with a quart of the same gasoline and add a little amount of water and debris... You can see how the water and debris will stay in the chamois side of the funnel, nothing on the fuel.
Here we have a big old galvanized funnel with a chamois rag, can easy hold about 4 galons of gas. In our aerodrome we dont have gas, so we bring our own, all goes though the funnel before going to the tank...
For xcountries we take a little black one (about 1 or 2 quarts capacity) that I brought from a vacation trip (visited Aircraft Spruce in Corona Smile but is slower and the fuel cans are heavy... Smile
Saludos
Gary Gower
--- On Wed, 11/25/09, kmccune <kmccune(at)somtel.net> wrote:
Subject: Re: electric fuel pump behind seat of a 701?
Date: Wednesday, November 25, 2009, 7:24 AM
--> Zenith701801-List message posted by: "kmccune" <kmccune(at)somtel.net (kmccune(at)somtel.net)>
I have never heard of this, interesting.
Kevin
ggower_99(at)yahoo.com wrote:
a Gascolator is enough if we pass the fuel though a Chamois cloth before the gas tank. As the old pilots do.
Saludos
Gary Gower.
--- On Mon, 11/23/09, Tom Longo wrote:
History is a great teacher if you take time to study it.
Steve Bennett
http://forums.matronics.com/viewtopic.php?p=274736#27473= * The Builder's Bookstore www.buildersbooks.com= --> http://www.bsp; ========================http://www.matroni --> http:========================
n4546v(at)mindspring.com
PostPosted: Tue Dec 01, 2009 12:05 pm    Post subject: Zenith701801-List:Re: electric fuel pump behind seat of a 70 Reply with quote
as stated below, a chamois,
Main Entry: cham·ois
Pronunciation: \ˈsha-mē, sense 1 also sham-ˈwä\
Function: noun
Inflected Form(s): plural cham·ois also cham·oix \sense 1 ˈsha-mē(z) or sham-ˈwä(z), senses 2 & 3 ˈsha-mēz\
Etymology: Middle French, from Late Latin camox
Date: 1560
1 : a small goatlike bovid (Rupicapra rupicapra) of mountainous regions from southern Europe to the Caucasus
2also cham·my or sham·my \ˈsha-mē\ : a soft pliant leather prepared from the skin of the chamois or from sheepskin
3 : a cotton fabric made in imitation of chamois leather
while lining a funnel, will filter out water and debris. When I was a float pilot, we had to "jug" fuel down to the lake from our tank on the strip. We always ran the fuel through a chamois.
It's been a long time, but I recall being told that if water was filtered out, it should be removed from the chamois quickly as it would slowly soak into the chamois, wetting a spot which then provided a channel for water to wick through thus defeating the water filtering ability of the chamois.
I never had any real water problem in my fuel so maybe others (Gary?) could comment, agree, disagree, or clarify that this is something one would watch while using a chamois.
I still have a chamois and the same old funnel in the hanger. Our airport fueling operation is very clean, but if we have to drain a tank into jugs, it goes through the chamois when going back in. I keep the chamois rolled up and stored in a screw top jar (instant coffee type) to keep it clean when not in use.
Randy, Las Vegas
Hello Kevin,
Saludos
Gary Gower
kmccune
PostPosted: Tue Dec 01, 2009 2:26 pm    Post subject: Re: Zenith701801-List:Re: electric fuel pump behind seat of Reply with quote
Thanks for the info!
Kevin
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
PostPosted: Wed Dec 02, 2009 9:56 am    Post subject: Zenith701801-List:Re: electric fuel pump behind seat of a 70 Reply with quote
Hello Randy,
Sure I remember that only once in a fligh to the coast, when I made my preflight in the morning for take off, I found a big drop of water in the fuel sampler, I think was from condensation.
I have found sometimes a little water and some debris in the chamois, from the gas station or maybe from the jug, but then we wash and dry the chamois once we finish the fill up.
We were told always to do that (never leave the chamois dirty or with water), but didnt know why until now that I read your post. Thank for the explanation.
Saludos
Gary Gower
Flying from Chapala, Mexico
701 912S
601 XL Jab 3300 waiting for the Update kit.
--- On Tue, 12/1/09, Randy L. Thwing <n4546v(at)mindspring.com> wrote:
Subject: Re: Zenith701801-List:Re: electric fuel pump behind seat of a 701?
Date: Tuesday, December 1, 2009, 3:04 PM
Function: noun
Date: 1560
Randy, Las Vegas
Hello Kevin,
Saludos
Gary Gower
_blank rel=nofollow>www.aeroelectric.com
/" target=_blank rel=nofollow>www.buildersbooks.com
=_blank rel=nofollow>www.homebuilthelp.com
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith701801-List
