jchang10
Posted: Thu Dec 03, 2009 7:35 am Post subject: Leg Gear Fairing Hinge Pins - bottom or top? |
The plans have you install this pin from the bottom, which seems odd.
Also, this requires securing the pin from falling and possibly removing
the wheel pants to insert the pin.
However, has anyone installed the pin from the top of the leg? It looks
like it might work and less worry about the pin falling out.
Jae
40533
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Posted: Thu Dec 03, 2009 8:12 am Post subject: Leg Gear Fairing Hinge Pins - bottom or top? |
| Quote: | From the bottom, the pin is kept in place by the lower fairing...
kdbelue(at)charter.net Guest
Posted: Thu Dec 03, 2009 8:55 am Post subject: Leg Gear Fairing Hinge Pins - bottom or top? |
I installed mine from the top and that works fine for me.
Kevin Belue
RV-10 flying
RV-6A flying
On Dec 3, 2009, at 9:33 AM, Jae Chang <jc-matronics_rv10(at)jline.com>
wrote:
odd. Also, this requires securing the pin from falling and possibly
removing the wheel pants to insert the pin.
looks like it might work and less worry about the pin falling out.
Jae
40533
partner14
Posted: Thu Dec 03, 2009 9:11 am Post subject: Leg Gear Fairing Hinge Pins - bottom or top? |
I also install mine from the top.... works fine.
Don McDonald
--- On Thu, 12/3/09, Kevin Belue <kdbelue(at)charter.net> wrote:
Subject: Re: Leg Gear Fairing Hinge Pins - bottom or top?
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Thursday, December 3, 2009, 8:50 AM
--> RV10-List message posted by: Kevin Belue <kdbelue(at)charter.net (kdbelue(at)charter.net)>
Kevin Belue
RV-10 flying
RV-6A flying
On Dec 3, 2009, at 9:33 AM, Jae Chang <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)> wrote:
| Quote: | --> RV10-List message posted by: Jae Chang <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)>
The plans have you install this pin from the bottom, which seems odd. Also, this requires securing the pin from falling and possibly removing the wheel pants to insert the pin.
However, has anyone installed the pin from the top of the leg? It looks like it might work and less worry about the pin falling out.
Jae
>= this year's Terrific Free Incentive Gifts provided
="http://www.matronics.com/contribution" target=_blank>http://www.matro -Mattvigator?RV10-List" sp;--> http://f=======================
40636 |
jchang10
Posted: Fri Dec 04, 2009 7:03 am Post subject: Leg Gear Fairing Hinge Pins - bottom or top? |
Thanks for the replies. I finally got a chance to test it both ways
again and the bottom up approach with wheel pants off seems the best for
me, without permanently bending the pin.
I was also thinking I may try to pop rivet some safety wire permanently
in place by the hinge. Then I can twist and untwist the safety wire as
needed.
Jae
40533
Posted: Fri Dec 04, 2009 7:35 am Post subject: Leg Gear Fairing Hinge Pins - bottom or top? |
Just a suggestion but after about three or four twists and untwists the wire will most likely give out The way that pin slides in and out I never wired it in place My pant fairings are bonded to the pant itself and I can't see how the fairing pin could ever find is way out.
Rick S.
N246RS
