Roger Lee
Posted: Tue Dec 01, 2009 3:31 pm Post subject: Engine ring mount bolts |
Hi All,
Just an FYI.
Make sure you put a torque wrench on your 4 engine ring mount bolts at every annual or 100 hr. inspection if you use the standard Rotax engine mount. I keep finding them a little loose. Rotax manual has you torque them to 30 ft/lbs. The top left bolt is the only bolt you will need an 8mm ball end allen wrench. The other 3 you only need an 8mm flat tipped allen wrench.
| - The Matronics RotaxEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Dick Maddux
Posted: Wed Dec 02, 2009 6:02 am Post subject: Engine ring mount bolts |
Thanks for the info Roger. I have a conditional coming up and I will check the mounts !
Dick Maddux
Milton,Fl
