mhubel
Posted: Tue Dec 08, 2009 6:28 am Post subject: Removing solid rivets |
I am looking for suggestions on removing the solid rivets on the main spar. I have had a rivet stuck, even using a rivet gun with a punch will not budge it. While I might drill this one out and replace it with a bolt, any ideas to deal with others would be appreciated.
Also, is it an option at all to drive out a rivet from the back (bucked end)? The heads of some rivets are behind the rear ribs and I worry about damaging the ribs while attempting to remove these rivets.
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
carlossa52(at)gmail.com Guest
Posted: Tue Dec 08, 2009 6:52 am Post subject: Removing solid rivets |
You might want to take a look into this document:
http://www.oshkosh365.org/saarchive/eaa_articles/1993_05_11.pdf
Carlos
CH601-HD, plans
2009/12/8 mhubel <mhubel(at)nemon.com (mhubel(at)nemon.com)>
[quote] --> Zenith601-List message posted by: "mhubel" <mhubel(at)nemon.com (mhubel(at)nemon.com)>
Mark Hubelbank
Thruster87
Posted: Tue Dec 08, 2009 11:57 am Post subject: Re: Removing solid rivets |
| mhubel wrote: | I am looking for suggestions on removing the solid rivets on the main spar. I have had a rivet stuck, even using a rivet gun with a punch will not budge it. While I might drill this one out and replace it with a bolt, any ideas to deal with others would be appreciated.
Also, is it an option at all to drive out a rivet from the back (bucked end)? The heads of some rivets are behind the rear ribs and I worry about damaging the ribs while attempting to remove these rivets. | If you can remove the tail cleanly there is no reason you can't drive it out backwards.I little bit of brute force may sometimes be of benefit so long as you don't go over board,the metal does have spring back [ribs] within reason.I had a couple of tough customers as well but persistence pays off and ear muffs. Cheers T87
Afterfxllc(at)aol.com Guest
Posted: Tue Dec 08, 2009 11:58 am Post subject: Removing solid rivets |
Try putting the punch in a drill press and using that as a press try and remove it. If that doesn't work go to the next size larger drill bit and keep working your way up until it comes out.
Jeff
mhubel
Posted: Tue Dec 08, 2009 4:01 pm Post subject: Re: Removing solid rivets |
Thanks for the suggestions, I will be back at the hanger in a couple of days and will see how things work out.
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Wed Dec 09, 2009 9:17 am Post subject: Re: Removing solid rivets |
Mark,
I have driven out rivets both ways and neither is better than the other. Just depends on what way you want to drive them out. The key I found is to make sure you clamp the spar materials tightly on both sides of the rivet you want to drive out. Otherwise the layers separate, binding the rivet in. If you have one that just will not come out, counter drill it with a smaller bit a little at a time until you get to where it will come out. I had some where I was convinced that it would NEVER come out, but they did.
Good luck!!
_________________ David Gallagher
Cincinnati, OH area |
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Wed Dec 09, 2009 8:04 pm Post subject: Re: Removing solid rivets |
I made a mistake early on where I had to remove all the rivets from my spars. Like you I found some of them would not budge. I solved the problem by making a little jack. I was able to make this jack using only the following tools. A drill press and a bench grinder, hack saw and a tap. It tooks only a hour or 2 to make. With this tool the rivets came out easily. Check it out on my website.
http://daniel.dempseyfamily.us/zodiac/wings/BigGoof/index.html
_________________ Scratch building XL with Corvair Engine |
