kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Mon Dec 07, 2009 4:41 pm Post subject: Old swing forward doors |
What is the disadvantage of this type of door?
I see less worry about door opening/falling off in flight...see stolspeed.com.
Easier flip/slid open window section modification.
No worry's about gas drips... sorry Tommy!
Easy to take off/on
Tell me the down side
Kevin
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
Curt.Thompson(at)verizon. Guest
Posted: Mon Dec 07, 2009 4:53 pm Post subject: Old swing forward doors |
It needs to clear the strut. Correct?
Curt
klondike(at)megalink.net Guest
Posted: Mon Dec 07, 2009 5:19 pm Post subject: Old swing forward doors |
it will, if built to plans--------do not archive
b.carl@sympatico.ca
Posted: Tue Dec 08, 2009 4:51 am Post subject: Old swing forward doors |
Kevin
I built from plan in 94 and designed my own flip-ups because they are easier
to deal with while docking on floats. Also two of my friends who built from
kits had issues with their swing doors interfering with the wing strut.
I agree with the disadvantages you listed. I resently installed buble doors.
They do increse elbow room, are more riggid and look nicer. However they may
create low preasure areas under the wing (not good for lift) and increase
drag. I have not been able to prove this as I foolishly destroyed my old
doors.
Carl
Posted: Tue Dec 08, 2009 8:24 am Post subject: Old swing forward doors |
The reason I mentioned the interference with the strut is that I saw a CH701
with a notch out of the lower rear corner of the door. It looked like it
was there so the door would clear the strut. This door mod created a gap
when the door was closed. It looked like an afterthought.
Curt
John Bolding
Posted: Tue Dec 08, 2009 8:49 am Post subject: Old swing forward doors |
The Bearhawk has the same problem, Barrows designed a little hinged
alum.flap to clear the strut and seal the door. I have a set of Bearhawk
drawings, if anyone gets really serious about going this way I'll dig out
that drawing for them.
LO&SLO John
cdnch701(at)mts.net Guest
Posted: Tue Dec 08, 2009 10:46 am Post subject: Old swing forward doors |
Also if you check the old drawing and compare it to the new drawings... you will
notice that the doors are a bit shorter on the old... Ron
saw a CH701 with a notch out of the lower rear corner of the door.
It looked like it was there so the door would clear the strut.
This door mod created a gap when the door was closed. It looked
Curt
kmccune
Posted: Thu Dec 10, 2009 4:26 am Post subject: Re: Old swing forward doors |
The drawings I have show the older door opening slightly longer.
Kevin
Dorothy McCune |
