WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Tue Dec 08, 2009 6:53 pm Post subject: Washed gas and Leaded gas |
So here is the new topic on my mind;
First and foremost, has anyone here have any FIRST HAND experience with washing ethanol out of fuel? I would like to hear about it.
I have read here and on other sites about simply adding water and then draining off the ethanol free fuel but it just sounds wrong to me.
I am planning on replacing my fuel tanks with E compatible ones but I am not ready yet because I have not allocated the cash first of all but also I am still concerned about the down time so I am going to wait until deeper into winter when I will not be too upset about not flying for a few weeks. When I first started to run into the issue with no ethanol free fuel in my area I was told that the plug fouling was the only major issue with 100LL but that is not sounding like the case right now. I am probably 40 hours into running straight 100LL and I am wondering if I am putting my engine (and butt) at risk. So I really need to figure out a solution and preferably by Saturday.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Dick Maddux
Posted: Wed Dec 09, 2009 4:39 am Post subject: Washed gas and Leaded gas |
You wash away the octane too, not good.
Dick Maddux
Milton,Fl
Lion8
Posted: Wed Dec 09, 2009 5:15 am Post subject: Washed gas and Leaded gas |
Wash out ethanol out? Yes Dick, I took a big glass jug. I put exactly 5 gal. in. I poured a measured 1qt. of water. Mixed it up a bit. The next day I drained out just under 2 ltr.'s of cloudy liquid. It wasn't gas. I set this on a shelf for a few days. As I walked around the shop, I kept smelling White Lightning (pure grain alcohol). \
Didn't put the stripped gas in my plane-I dumped it into my truck. Because I don't know what else I stripped out, I will not fly with it. To lower the ethanol I cut the mogas with no more than 1/2 100LL and add seafoam. -'Lion 8'- (Tom)
_________________ Tom (Lion8), Currently Flying an LSA Trike
Rebuilding a Kitfox IV Speedster
Southern New Jersey |
napierm(at)cisco.com Guest
Posted: Wed Dec 09, 2009 7:06 am Post subject: Washed gas and Leaded gas |
Hey James,
I've heard other talk about washing gas too but there is a problem with
that. The alcohol raises the octane rating of gas. Because of this the
refiners actually ship a product that has a lower octane rating and when
mixed with 10 percent alcohol it then has the octane rating shown on the
pump.
Taking the alcohol back out reverses the process. Now what the octane
rating is without the alcohol I don't know. I *guess* you could buy the
93 octane gas (if you can find it) and be able to lose a few octane
points and still be OK. Long term I think it's easier to change the
tanks and be done with it.
As for the 100LL, it was my mistake for not using a lead scavenger in
the gas when going x-country. I would absolutely recommend using it if
you are burning strait avgas. I don't know what to say about what oil
to use with it; others here have some good suggestions.
I've also heard of the guys using "Sea Foam" to clean the rings, but
again, I have no direct experience. Rotax says to pull the cylinders at
150 hours and clean the rings. Based on my experience I would say
that's good advice. You can't really tell if the ring is free without
getting the piston in your hand. A set of aftermarket of seals (I've
used these and they are perfectly good except for the crankshaft end
seals) will only cost about $50 to do the job. Just the top end seals
are only $30.
Gaskets: http://www.mfgsupply.com/m/c/711194.html
HKS still runs and recommends running car gas. But they are near a
marina in FL and can still get E0 fuel there.
FWIW,
Mark Napier
Time: 06:55:34 PM PST US
Subject: Washed gas and Leaded gas
From: "WurlyBird" <james.t.trizzino(at)us.army.mil>
washing
draining
not ready
still
winter
first started
that
sounding
100LL
really
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
http://forums.matronics.com/viewtopic.php?p 76778#276778
WurlyBird
Float Flyr
Posted: Thu Dec 10, 2009 2:56 pm Post subject: Washed gas and Leaded gas |
On the other list I mentioned I had my outboard motror tank submerge several times when I was a kid. Of course in those days there was lead in the gas which would not wash out with a bit of water. You are quite rigt that you will reduce the RON of your gas by removing the ethanol.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Wednesday, December 09, 2009 9:09 AM
Subject: Re: Washed gas and Leaded gas
Dick Maddux
Milton,Fl
| Quote: | | www.aeroelectric.com | 0123456789012345678
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Not washing ethanol out of the gas... We don't have ethanol here. But
several times when I was a kid I had my outboard motor tank submerge and had
to drain off the water. No problem.
Noel
Kitfox III-A
Float Flyr
Posted: Thu Dec 10, 2009 3:06 pm Post subject: Washed gas and Leaded gas |
Ethanol is supposed to have a RON of 116, normal (whatever that is) gas 87 so washed gas mixed 50/50 with 100LL would have a RON of 93.5 with half the lead of  100LL. Because the 582 doesn’t require high octane fuel I’d use it in fact I think I’d go to 4:1 washed:100LL and reduce the lead even further.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of ctmcdowell(at)comcast.net
Sent: Wednesday, December 09, 2009 9:43 AM
Kitfox III-A
