WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Tue Dec 15, 2009 6:43 pm Post subject: Repairman Certificate |
Can anyone tell me where to look or who to call to find the nearest repairman class?
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Tue Dec 15, 2009 8:31 pm Post subject: Re: Repairman Certificate |
EAA would be good place to start.
I'm taking the 16 hour E-LSA class this coming January 29-31, in Oshkosh, WI.
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
Tom Jones
matronics(at)bob.brennan. Guest
Posted: Wed Dec 16, 2009 6:50 am Post subject: Repairman Certificate |
I got my repairman's certificate through the EAA's Sportair program - they
have classes all around the country. Here is the link and the schedule of
upcoming classes:
http://www.sportair.com/
http://www.sportair.com/schedule.html
Be aware that these classes are *only* for the owner of an airplane that
has, or will have, and ELSA Airworthiness Certificate. If you are the
builder of an EAB airplane you don't need to take this course to get your
Repairman's Certificate, just apply for it through your DAR when getting
your airworthiness inspection - he must sign off that you are "knowledgable"
enough to do your own inspections. If you are not the builder of an EAB, or
the owner of an ELSA, you cannot get a Repairman's Certificate (unless of
course you are a full A&P, but then you don't need one!)
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade GSC prop
Wrightsville Pa
