deej(at)deej.net Guest
Posted: Sat Apr 15, 2006 6:33 am Post subject: antenna construction |
Hi all,
I'm sure I ran across a web site with information on
constructing your own antennas for aircraft use (wingtip
and/or inside a fiberglass fuselage). I can't seem to find
the site, though. Anyone have a lead on this?
-Dj
Dj Merrill - N1JOV
Sportsman 2+2 Builder #7118
http://econ.duke.edu/~deej/sportsman/
"TSA: Totally Screwing Aviation"
BigD(at)DaveMorris.com Guest
Posted: Sat Apr 15, 2006 6:58 am Post subject: antenna construction |
If your fuselage is composite and has the requisite inside diameter,
you can take advantage of a loop antenna design that has gain, lower
noise, and requires no ground plane:
www.DaveMorris.com/MorrisComLoop
Dave Morris
At 09:30 AM 4/15/2006, you wrote:
Hi all,
-Dj
Dj Merrill - N1JOV
khorton01(at)rogers.com Guest
Posted: Sat Apr 15, 2006 12:42 pm Post subject: antenna construction |
On 15 Apr 2006, at 10:30, Dj Merrill wrote:
Hi all,
http://www.rst-engr.com/
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Sun Apr 16, 2006 7:22 am Post subject: antenna construction |
Kevin Horton wrote:
Hi Kevin,
Thanks for the link! That wasn't the site I was thinking of but
that looks like a good one. They have a booklet they sell for $5 that
apparently has several airplane antenna plans in it, and probably worth
getting to have on hand.
The site I was thinking of had plans and list of materials
on it so you could build the antennas yourself from raw parts. I've
tried Google with no luck, and I can't seem to find the bookmark for the
site. Ah well...
-Dj
Dj Merrill - N1JOV
jschroeder(at)perigee.net Guest
Posted: Sun Apr 16, 2006 11:29 am Post subject: antenna construction |
DJ-
We got a kit from RST Engineering that had a roll of copper foil tape and
some other harware to make dipole antennas. We put a VOR and a glideslope
antenna in the wing of our Lancair ES and they work great. The kit comes
with a booklet with all the info you need to make just about every kind of
antenna. Call Jim Weir and ask if he still does the kit.
Hope this helps,
John Schroeder
On Sun, 16 Apr 2006 11:17:56 -0400, Dj Merrill <deej(at)deej.net> wrote:
Hi Kevin,
site. Ah well...
-Dj
