sarg314(at)gmail.com Guest
Posted: Sat Dec 19, 2009 9:06 am Post subject: where to put fire extinguisher |
I just realized I haven't mounted my fire extinguisher yet. Â Is there a "standard" spot for this in an RV-6A? Â Looking for an easy (=quick) installation idea.
Tom Sargent
sportav8r(at)gmail.com Guest
Posted: Sat Dec 19, 2009 12:58 pm Post subject: where to put fire extinguisher |
How about under the cowl with a remote pull pin? Just kidding. Or maybe not.
I had a small Halon bottle lying loose in my custom panel glove box, until the day my wife shut the door on it with some loose object (probably a CD player) in front of the discharge button. Hissing noise and "smoke" in flight made me think a 2 gauge cable had shorted to ground for a second. We laughed later. A lot later.
Bill /Stormy / 6A
On Sat, Dec 19, 2009 at 11:40 AM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
[quote] I just realized I haven't mounted my fire extinguisher yet. Is there a "standard" spot for this in an RV-6A? Looking for an easy (=quick) installation idea.
Tom Sargent
_blank">www.aeroelectric.com
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
| [b]
bob194bn(at)verizon.net Guest
Posted: Sat Dec 19, 2009 2:55 pm Post subject: where to put fire extinguisher |
I mounted mine between seats that way piolot or passenger has access to extinguisher
To: rv-list <rv-list(at)matronics.com>
Sent: Sat, December 19, 2009 8:40:16 AM
Subject: where to put fire extinguisher
Tom Sargent
| Quote: | www.homebuilthelp========================
sbuc(at)hiwaay.net Guest
Posted: Sat Dec 19, 2009 4:43 pm Post subject: where to put fire extinguisher |
On 12/19/2009 10:40 AM, thomas sargent wrote:
| Quote: | I just realized I haven't mounted my fire extinguisher yet. Is there a
installation idea.
In my RV-6, the extinguisher is mounted on the floor just in front of
the fuel valve.
Sam Buchanan
Posted: Sat Dec 19, 2009 5:27 pm Post subject: where to put fire extinguisher |
How about on the spar cover where it's just behind your legs and handy .... under the cowl won't help with a brake fire.
Linn
Bill Boyd wrote: [quote]How about under the cowl with a remote pull pin? Just kidding. Or maybe not.
Bill /Stormy / 6A
| Quote: | I just realized I haven't mounted my fire extinguisher yet. Is there a "standard" spot for this in an RV-6A? Looking for an easy (=quick) installation idea.
Tom Sargent
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
Dale Ensing
Posted: Sat Dec 19, 2009 5:48 pm Post subject: where to put fire extinguisher |
Tom
I have mine between the seat bottom cushions. It's a little too long to lay flat on the floor between the flap drive enclosure and the tapered portion of the seat bottom. But, a little sheet aluminum fabrication made a bracket to fit.
Dale Ensing
RV-6A
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Gary.A.Sobek
Posted: Sat Dec 19, 2009 6:04 pm Post subject: where to put fire extinguisher |
In my RV-6 C I mounted mine on the F-638 Seat Back Brace of the Passenger Seat. I used the bracket that it came with and made some Velcro straps to help hold it in plus make it easy to remove. While in flight C I can reach over and pull it off. No bending or twisting.
I copied this idea off of Bill Flahrty RV-6 when I saw it in July 1998 at 2G3 (now KVVS). It has held up well for almost 12-years and over 2 C000 hours of flying.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell C
2 C338+ Flying Hours So. CA C USA
Date: Sat C 19 Dec 2009 09:40:16 -0700
To: rv-list(at)matronics.com
Thanks C
Tom Sargent
Hotmail: Trusted email with powect/01/' target='_new'>Sign up now. [quote][b]
peterhunt1(at)aol.com Guest
Posted: Sun Dec 20, 2009 12:58 pm Post subject: where to put fire extinguisher |
I put mine under my knees mounted horizontally on the forward side of the main spar. It is easy to reach between my knees, very secure in its holder, yet out of the way.
Pete in Clearwater
RV-6, Reserve Grand champion and more
Posted: Mon Dec 21, 2009 3:53 pm Post subject: where to put fire extinguisher |
Pete:
Didn't that interfere with your left tank fuel line? Did you attach it to the spar itself?  So, the fire ext. mount would have to be removed to take out the wing? (Not an criticism, just trying to understand how you mounted it).
On Sun, Dec 20, 2009 at 1:57 PM, <peterhunt1(at)aol.com (peterhunt1(at)aol.com)> wrote:
| Quote: | I put mine under my knees mounted horizontally on the forward side of the main spar. It is easy to reach between my knees, very secure in its holder, yet out of the way.
Â
Pete in Clearwater
Â
Tom Sargent
