plasma cutter
JHearnsberger
PostPosted: Tue Dec 22, 2009 8:37 am    Post subject: plasma cutter Reply with quote
Would there be anything wrong with using a plasma cutter for trimming? I am just starting a RV-10 Empennage.
Jake
pitts_pilot(at)bellsouth.
PostPosted: Tue Dec 22, 2009 9:06 am    Post subject: plasma cutter Reply with quote
I wouldn't say 'wrong'.
You can cut most anything that's electrically conductive with a plasma
cutter.
But, you'd be just as well off to use an ax.
Linn
Jake
http://forums.matronics.com/viewtopic.php?p 78576#278576
JHearnsberger
PostPosted: Tue Dec 22, 2009 9:15 am    Post subject: Re: plasma cutter Reply with quote
Should I stick to the band saw for all of my cutting?
tsts4
PostPosted: Tue Dec 22, 2009 9:29 am    Post subject: Re: plasma cutter Reply with quote
Well, there's usually more than one way to perform any building task, but there's also usually a way that gives the best results and/or is the easiest to get the task done. I pick the tool that gets me what I want. A lot of times that is the band saw, other times it's a cutoff wheel in a die grinder (I also use a small wheel in a Dremel for fine cuts). I have also used a nibbler and tin snips. Bottom line, use whatever it takes to get the job done. For my money, the saw and a cutoff wheel will handle pretty much all of your cutting tasks.
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
PostPosted: Tue Dec 22, 2009 9:35 am    Post subject: plasma cutter Reply with quote
Sooo much better! The best advice I can offer is to use the proper tool
for the job ..... and use it properly. Trimming aluminum may involve
the bandsaw; left, right, and straight 'aviation tin snips'; files of
all types and sandpaper .... belt sanders and disc sanders.
Linn
http://forums.matronics.com/viewtopic.php?p 78580#278580
rbibb
PostPosted: Tue Dec 22, 2009 3:05 pm    Post subject: plasma cutter Reply with quote
Jake:
I usually think of a plasma cutter when wanting to cut steel. The kerf on
all but the best models is pretty rough. Not sure how well they do on
aluminum.
Richard Bibb
972-771-2598
972-835-5979 mobile
Bob Turner
PostPosted: Tue Dec 22, 2009 4:57 pm    Post subject: Re: plasma cutter Reply with quote
I know nothing about these things. But, I do know the aluminum we use is almost always heat treated. You wouldn't want to change that treatment in any load bearing area.
Bob Turner
RV-10 QB
roxianmike(at)msn.com
PostPosted: Tue Dec 22, 2009 6:29 pm    Post subject: plasma cutter Reply with quote
I have a little experience with a plasma cutter in a prior life and based upon the units I have used C it would be a bit of over kill unless more modern units allow you to dial it down to an extremely fine flow..............I would expect it to blow away too much aluminum.......I guess you asked for opinions and mine would be to use less powerful tools on this soft aluminum as suggested by others that have replied...........good luck and welcome to the "club".
Subject: plasma cutter
Date: Tue C 22 Dec 2009 08:37:28 -0800
--> RV10-List message posted by: "JHearnsberger" <jakehearnsberger(at)gmail.com>
Thanks C
Jake
http://forums.matronics.com/viewtopic.php?p=278576#278576
&gt================
PostPosted: Tue Dec 22, 2009 7:02 pm    Post subject: plasma cutter Reply with quote
One of the nice things about plasma cutters ..... the heat doesn't seem
to go too far from the kerf.
Works better on steel, but leaves a little dross on the bottom edge when
cutting aluminum. Easily cleaned up, but making an accurate cut is near
impossible. Does make a wonderful cut on stainless though.
Linn
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p 78626#278626
JHearnsberger
PostPosted: Wed Dec 23, 2009 8:17 am    Post subject: Re: plasma cutter Reply with quote
Thank you all for your information. It never hurts to ask.
