dreel(at)cox.net Guest
Posted: Mon Apr 17, 2006 5:45 am Post subject: Flaky BNC Connection Repairable? |
I've noticed the satellite signal strength indicators on my GPS90 vary when I rotate or wiggle the antenna cable where it goes into the BNC connection on the GPS. So far, this hasn't seemed to affect operation in the air, but, since I rely heavily on this mode of navigation, I'm wondering if there is something I could do, short of replacing the unit, to give me a better connection. Some sort of conductive grease or spray? The antenna cable is new but the GPS is 8 years old. I'll soon be going out on tiedown & the unit is mounted to the panel & uses ship's power, so it's environment is about to become more hostile too.
Dave Reel - RV8A
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Apr 17, 2006 6:34 am Post subject: Flaky BNC Connection Repairable? |
DAVID REEL wrote:
One should pull all panel mounted radios about once per year anyway in
order to clean them, blow out the dust, and clean the connectors. You
may find that solves any problems you may have.
Given that almost all BNC connectors use gold pins, corrosion and
contact resistance are usually not a problem. If you are having problems
with the antenna connector then you need to troubleshoot this before you
have an in-flight failure. Remember, most GPS antennas have their own
amplifier built-in that is powered by DC power going up the antenna coax
cable. It is more likely that it is DC resistance changing the voltage
arriving at the GPS antenna that is causing your problem.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Dale Ensing
Posted: Mon Apr 17, 2006 9:10 am Post subject: Flaky BNC Connection Repairable? |
Dave,
I recently discovered the ring nut that holds the BNC connector was loose in
my Garmin 295 allowing it to turn in the housing. You might check that on
yours.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
klehman(at)albedo.net Guest
Posted: Mon Apr 17, 2006 2:59 pm Post subject: Flaky BNC Connection Repairable? |
Hi David
If certain there is not a real correctable cause (there usually is) -ypu
could try Stabilant 22a. I have not tried it on antenna connections but
it supposedly pretty much removes the need to periodically clean
connectors and seems to help with intermittent connections. Or maybe it
just makes me feel better .... I haven't noticed it advertised
lately although I seldom go to the places that used to advertise it
anymore.
Ken
DAVID REEL wrote:
Dave Reel - RV8A
