clint_bazzill(at)hotmail. Guest
Posted: Mon Jan 25, 2010 10:18 am Post subject: Leading edge to center of wheel. |
Hi C
I need to know measurement from leading edge of wing to center of wheel on Model IV with Grove gear.
Clint
bsvienus(at)hotmail.com Guest
Posted: Mon Jan 25, 2010 10:30 am Post subject: Leading edge to center of wheel. |
Tail wheel or nose wheel
Subject: Leading edge to center of wheel.
Date: Mon C 25 Jan 2010 18:15:10 +0000
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} Hi C
Clint
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
| Hotmail: Free C trusted and rich target='_new'>Get it now. [quote][b]
kirkhull(at)kc.rr.com Guest
Posted: Mon Jan 25, 2010 11:34 am Post subject: Leading edge to center of wheel. |
Assuming you are looking for the arm of the mains after installing the grove gear for a weight and balance calc it is 0 on my fox
You might want to check by leveling the a/c then dropping a string with a weight in it from the leading edge and measuring to the center of the wheel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clint Bazzill
Sent: Monday, January 25, 2010 12:15 PM
To: Kitfox list
Hi,
Clint | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Pat Reilly
Posted: Mon Jan 25, 2010 2:51 pm Post subject: Leading edge to center of wheel. |
Clint. By leveling the plane, Kirk means put it in level flight attitude. That would be the door sill level, fore to aft. Then drop a plumb bob to the floor from wing leading edge and center of wheel.. That would be the only way to do it for any plane and it will differ with the different gear. You need to do that for any weight and balance calculations. It's a hell of alot better than taking someone elses figures for their plane.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Mon, Jan 25, 2010 at 1:33 PM, kirk hull <kirkhull(at)kc.rr.com (kirkhull(at)kc.rr.com)> wrote:
From: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of Clint Bazzill
To: Kitfox list
Subject: Kitfox-List: Leading edge to center of wheel.
Hi,
Clint0 1 2
