Lew Gallagher
Posted: Thu Jan 28, 2010 6:22 pm Post subject: Aileron trim servo |
Hey Guys,
I'm following up on Linn's advice to teach myself about the Parallax micro controllers and servos for aileron/rudder trim ... not for this project, but for the next one down the road.
It looks like there are MANY small hobby servos out there (Futaba) but with many different torque capacities. Can somebody who's been this path before give me a model number that works? These are durable and powerful enough? Probably not a good idea to put them under the cowl to control air flow to oil cooler, etc.?
I haven't gotten into it yet, but I'm also wondering how you get the power supply down to 9v for the Stamp board?
I know it's easier to just order Van's, etc. but I really like the challenge and learning opportunity.
Later, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
Posted: Thu Jan 28, 2010 7:48 pm Post subject: Aileron trim servo |
Lew Gallagher wrote:
<lewgall(at)charter.net>
Hey Guys,
I used the one from Parallax (it's a futaba) .... just because I was
ordering other stuff and already had one. I needed two for aileron and
rudder trim.
| Quote: | These are durable and powerful enough?
Well, it depends on the application, of course. I think any of them
would move a small trim tab. They make really powerful ones that may
even be able to be used as a door latch!
| Quote: | Probably not a good idea to put them
They're pretty rugged. Don't know for sure until someone tries it.
LM7809 available from Radio Shack. Cheaper elsewhere, but not with
shipping!!! I had used the BS2e on 12 V, but the voltage difference
between that and the serial line (5V) will fry the serial port. Worked
great until I tried to program it again!!!
I wanted to have my trim equipment inside the surface being moved, and
the small airplane servo fit the bill.
Linn
Later, - Lew
-------- non-pilot crazy about building NOW OFICIALLY BUILDER #40549
Painting done! On with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p 83871#283871
ricksked(at)cox.net Guest
Posted: Thu Jan 28, 2010 8:27 pm Post subject: Aileron trim servo |
Having quite a bit of R/C servo experience and Ray Allen being one of the first servo manufac. of servos for heavy duty use I can't see adapting some of the high speed/torq coreless bb servos for full scale use.
In the large scale and ducted fan/turbine R/C aircraft the precise high torq BB servos really do fit the bill. For trim tabs you might as well buy a sail winch servo.. R/C servos as far as I know always draw current to hold position. For a long flight your asking that servo to maintain position and work constantly leading to early failure and not designed for that kind of extended use like the Ray Allen trim servo which is geared to hold position all the time regardless if it has power...just something to think about...
Rick Sked
Posted: Thu Jan 28, 2010 8:48 pm Post subject: Aileron trim servo |
ricksked(at)cox.net wrote:
scale use.
The Ray Allen servo's are just a motor with gear train, needing to run
the motor forward and backwards. It has no 'positioning' capability
other than when you let your finger off the switch. The model airplane
servos are pulse width modulated (PWM) and seek a position based on the
pulse width.
? didn't understand that one. All I'm moving is a short length of hinge.
| Quote: | R/C servos as far as I know always
The MA servos seem to last a whole lot longer than the MAs do! <GR>
Once the MA servo gets to it's commanded position .... nothing moves
until the pulse width changes. True, it consumes a little power, but
it's miniscule.
I'm using the Ray Allen servo for the elevator trim only because it was
part of the kit when I bought it. I'd much rather have a smart servo
that moves in small increments independent of how quick I am on the
switch handle.
The only downside to using the MA servo is having to create the pulse width.
Linn
Rick Sked ---
Posted: Thu Jan 28, 2010 9:22 pm Post subject: Aileron trim servo |
True dat Linn but you are reinventing the wheel, and in my ignorance I thought the servos were pulse code modulation?? Same thing?? and you hit the nail on the head...Why do you need a proportional servo for trim? Motor, gear box done....the R/C servo adds an additional fail point in the form of a potentiometer right? You've succeeded in reinventing the trim system and since were friends I totally know why you're doing it...cause you can and you're retired and it's what ya do!!!
Rick
Sent via BlackBerry by AT&T
Posted: Fri Jan 29, 2010 7:42 am Post subject: Aileron trim servo |
Well, no. 'Code' implies information sent in a string of bits .... like
serial data. The Trio 'gold standard' servos use a serial link to send
positioning data.
| Quote: | and you hit the nail on the head...Why do you need a proportional servo
for trim?
Because you can control it's exact position by sending pulses of a known
width .... as in centering the trim, and you can control the speed
(rate)the servo moves by changing the pulse width just a little and
changing the time between pulses.
| Quote: | Motor, gear box done....the R/C servo adds an additional
Oh, it gets worse than that! What Lew and I are talking about is a
little computer-on-a-chip. It has 16 I/O pins and uses a little basic
program that most anyone can write with a little practice. I've used
them in other applications.
| Quote: | You've succeeded in
do!!!
Well, that's pretty much it .... I think it boils down to trim by
sledgehammer or mind-meld. My friends liken it to polishing a horse
turd .... what you get is a shiny turd. Prettier, but still the same.
Boils down to finess. Like the door SB. Sorry, couldn't resist!
Linn
Rick Do not archive Sent via BlackBerry by AT&T
