ian.sweeting(at)defence.g Guest
Posted: Thu Feb 11, 2010 3:44 pm Post subject: Ignition check [SEC=UNCLASSIFIED] |
UNCLASSIFIED Bob,
Try it at a lower RPM, say 1600. You could expect only a slight drop (eg <50RPM) which may not be perceptible at 2000.
Ian.
IMPORTANT: This email remains the property of the Department of Defence and is subject to the jurisdiction of section 70 of the Crimes Act 1914. If you have received this email in error, you are requested to contact the sender and delete the email.
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Robert Rivard
Sent: Friday, 12 February 2010 09:57
To: jabiruengine-list(at)matronics.com
Subject: Re: Ignition check
I have a 2200. When I do a run up and check the ignition at 2000 rpm there is no drop in rpm either left or right. Is this normal?
BOB
href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
