kearney
Posted: Fri Jan 29, 2010 5:46 pm Post subject: Bogi-Bar |
Hi
I just got a Bogie-Bar from ACS. I assume that it fits over either end of the nose gear axle bolt. Is this correct? If so, it seems that the Bogie-Bar spread is about 1/2" too wide to allow it to seat on the bolt. Am I missing something here?
Inquiring minds need to know
Cheers
Les
#40643
ricksked(at)cox.net Guest
Posted: Fri Jan 29, 2010 5:54 pm Post subject: Bogi-Bar |
It fits over the nose wheel fork aluminum block hex bolts that hold the blocks to the fork
Sent via BlackBerry by AT&TFrom: "Les Kearney" <kearney(at)shaw.ca>
Date: Fri, 29 Jan 2010 18:45:48 -0700
Subject: RV10-List: Bogi-Bar
Hi
I just = got a=20 Bogie-Bar from ACS. I assume that it fits over either end of the nose = gear axle=20 bolt. Is this correct? If so, it seems that the Bogie-Bar spread is = about 1/2"=20 too wide to allow it to seat on the bolt. Am I missing something=20 here?
Inquiring minds need=20 to know
Cheers
Les
#40643
bcondrey
Posted: Fri Jan 29, 2010 6:05 pm Post subject: Bogi-Bar |
It fits over the bolts that hold the trapazoid shaped aluminum spacers in. These thread into the sides of the nosewheel fork.
Bob
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com>
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: Fri Jan 29 17:45:48 2010
Hi
Cheers
Les
#40643
kearney
Posted: Fri Jan 29, 2010 6:21 pm Post subject: Bogi-Bar |
Rick
Thanks for the info. I looked at the plans but didn't think that would do as an attach point. I haven't installed these yet but will soon.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)cox.net
Sent: January-29-10 6:50 PM
Subject: Re: RV10-List: Bogi-Bar
Sent via BlackBerry by AT&T From: "Les Kearney" <kearney(at)shaw.ca>
Subject: Bogi-Bar
Hi
Cheers
Les
#40643
href='3D"http://www.matronics.com/Navigator?RV10-List"'>http://www.matronics.com/Navigator?RV10-List
href='3D"http://forums.matronics.com"'>http://forums.matronics.com
href='3D"http://www.matronics.com/contribution"'>http://www.matronics.com/contribution
| ¦·~‰²,g–ÓÓ [quote][b]
kearney
Posted: Fri Jan 29, 2010 6:34 pm Post subject: Bogi-Bar |
Hmmmm
Trapazoid. Damn, I wish I paid more attention in geometry class. That's a 12 sided whatzit isn't it....
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Condrey, Bob (US SSA)
Sent: January-29-10 7:04 PM
To: 'rv10-list(at)matronics.com'
Bob
Subject: Bogi-Bar
Hi
Cheers
Les
#40643
| ��~��,g�� [quote][b]
Posted: Fri Jan 29, 2010 10:19 pm Post subject: Bogi-Bar |
Lol....triangle with a flat spot on the 90 degree side....its plenty strong to tow the plane....everyone knows the trapazoid is used in the big top to swing on!!!
Date: Fri, 29 Jan 2010 19:34:32 -0700
Subject: RE: RV10-List: Bogi-Bar
Hmmmm
Trapazoid. Damn, I wish I paid more attention in = geometry=20 class. That's a 12 sided whatzit isn't it....
Cheers
Les
From: = owner-rv10-list-server(at)matronics.com=20 [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of = Condrey, Bob=20 (US SSA)
To:=20 'rv10-list(at)matronics.com'
Subject: Re: RV10-List:=20 Bogi-Bar
It fits over the bolts = that hold the=20 trapazoid shaped aluminum spacers in. These thread into the sides of the = nosewheel fork.
Bob
From: = owner-rv10-list-server(at)matronics.com=20 <owner-rv10-list-server(at)matronics.com>
To:=20 rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: = Fri Jan=20 29 17:45:48 2010
Subject: RV10-List: Bogi-Bar =
Hi
Cheers
Les
#40643
href=3D"http://www.matronics.com/Navigator?RV10-List">http://www.matronic=
href=3D"http://forums.matronics.com">http://forums.matronics.com
href=3D"http://www.matronics.com/contribution">http://www.matronics.com/c=
| =EF=BF=BD=EF=BF=BD~=EF=BF=BD=EF=BF=BD,=03g=EF=BF=BD=EF=BF= =BD [quote][b]
jchang10
Posted: Sat Jan 30, 2010 7:36 am Post subject: Bogi-Bar |
http://picasaweb.google.com/jchang10/Sec48GearLegAndWheelFairings?feat=directlink
There is a picture of mine and a little mod that was necessary for me to
do. While on the ground, I couldn't hold everything in alignment to fit
the bolt thru, otherwise.
Jae
40533
ricksked(at)cox.net wrote:
| Quote: | =EF=BB=BF Lol....triangle with a flat spot on the 90 degree
on!!!����i��0�f����r�(��(���n�b�xm����&j��',r��r��&�*'������������������'��k{��w/�tml=
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
coop85(at)verizon.net Guest
Posted: Sat Jan 30, 2010 7:56 am Post subject: Bogi-Bar |
Jae, great idea to keep things together, I usually spend way too much time with those parts. Looks like something for the to-do list on the next annual.
One lesson learned with the tow bars. While flying without wheel pants I let a lineboy move the airplane. He put the tow bar through one of the aft holes in the fork successfully shearing the valve stem as he moved the airplane. I don't let anyone touch it anymore, even with the wheel pants on.
Marcus
40286
