jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Fri Jan 29, 2010 5:12 am Post subject: 3d Model |
Has anyone taken the time to create a 3D model of the RV-10? I would like something to use to help in paint scheme design. I tried the aircraft painter that is available on the web, works OK, but it doesn't allow very much precision (control) in how lines transition from one surface to another.
Van's will not give me a model.....
Thanks, Jason
N44YH - Flying
Sheboygan Falls, WI
4 Partner Build [quote][b]
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
Lenny Iszak
Posted: Sat Jan 30, 2010 8:44 am Post subject: Re: 3d Model |
BTW, would someone be able to run a CFD plot on a 3D model of the RV-10?
It would be very interesting to see why the right side door is getting sucked out more than the pilot side, and also would give a more definite position of side louvers on the cowling.
Lenny
pietflyr(at)bellsouth.net Guest
Posted: Sat Jan 30, 2010 8:54 am Post subject: 3d Model |
Does the right side indeed get sucked out more than the left? If so, it is
almost certainly due to the corkscrew nature of the slipstream off the
propeller.
Jack Phillips
# 40610
Wings (Fuel Tanks)
