tomhanaway
Posted: Mon Feb 01, 2010 5:35 pm Post subject: Trimming sheath off Matco push pull brake cable |
Is there a good way to unspiral the sheath around the cable. I want to remove about 4 inches of sheath so I can attach the shortened push/pull cable to the parking brake.
Tom Hanaway
Boynton Beach, FL
ricksked(at)cox.net Guest
Posted: Mon Feb 01, 2010 5:53 pm Post subject: Trimming sheath off Matco push pull brake cable |
Pull the cable back past the cut point...NOT ALL the way...use a dremel cut off wheel then clean up the plastic with an Xacto knife
tomhanaway
Posted: Mon Feb 01, 2010 6:04 pm Post subject: Re: Trimming sheath off Matco push pull brake cable |
Rick
Thanks. Once you explain it, it seems so obvious. But until now, I sure didn't see it.
Tom
Phil.Perry(at)netapp.com Guest
Posted: Mon Feb 01, 2010 6:18 pm Post subject: Trimming sheath off Matco push pull brake cable |
Try smashing the sheath with a pair of needle nose pliers at the place
you want to cut. (Or closer to the end to test this method with your
sheath)
That'll spread the sheath a bit without damaging the internal cable.
Then you can use something (I've used a dremel) to cut the sheath where
it is spread open.
Phil
Posted: Mon Feb 01, 2010 7:54 pm Post subject: Trimming sheath off Matco push pull brake cable |
If you're talking of the 'choke cable' type, you can unwind it. Clamp
in a vise and unwind. Use a sharp edge file to create a fracture point
and then break by bending back and forth.
Linn
tomhanaway wrote:
Tom Hanaway
Boynton Beach, FL
http://forums.matronics.com/viewtopic.php?p 84510#284510
