Air Access on Wheel Farings
kearney
PostPosted: Sat Feb 13, 2010 5:41 pm    Post subject: Air Access on Wheel Farings Reply with quote
Hi
After reading all the advice about doing the farings etc before wings go on, I thought I would take a crack at my wheel farings. Seeing how inaccessible the inner tube valve stems are, I was wondering what the "best practise" is to deal with this issue.
Pix would be a bonus!
Inquiring minds need to know
Les
#40643 - still in a fibreglass cloud
gengrumpy(at)aol.com
PostPosted: Sat Feb 13, 2010 6:23 pm    Post subject: Air Access on Wheel Farings Reply with quote
Les,
First, get some new tubes from Desser that have the 90 degree bend on them (they do not make leak guard tubes with 90 degree bend). The straight stems end is too close to the axle nut, making getting a chuck on them a royal pain. Plus side is these tubes are about $13 each vice the $50 for leak guard.
Next, cut yourself a small access door that is hinged at the front. Put the door at the 9 o'clock position on the wheel looking at it from the side. Then use some tire chalk marker to mark the wheel at the 6 o'clock position when the stem is at the 9 o'clock.
That way, you can move the bird till you see the mark showing out the bottom of the wheel pant, then open the door and the stem is facing you ready for air up!
I fill my tubes with nitrogen to slow the inevitable slow leaks.
I just installed the remote pressure sensors (available thru Spruce) so I can monitor pressure without having to put a gauge on it. Takes a bit more lead weight to balance them, but it's worth it.
grumpy
N184JM
On Feb 13, 2010, at 7:40 PM, Les Kearney wrote:
Hi
Les
tp://www.matronics.com/Navigator?RV10-List
nics.com
w.matronics.com/contribution
= [quote][b]
gipsowh(at)hotmail.com
PostPosted: Sun Feb 14, 2010 6:54 am    Post subject: Air Access on Wheel Farings Reply with quote
Les, posed same question to VanAirforce crowd and posted pictures of my solution there.  Also, fashioned an angled nozzle to gauge and trigger assembly I bought at Walmart - an idea found on VAF.  Hope this helps.
Bill Gipson
Subject: RV10-List: Air Access on Wheel Farings
Date: Sat, 13 Feb 2010 18:40:43 -0700
Hi
Les
http://forums.matronics.com
Your E-mail and More On-the-Go. Ge29/direct/01/' target='_new'>Sign up now. [quote][b]
kearney
PostPosted: Sun Feb 14, 2010 7:55 am    Post subject: Air Access on Wheel Farings Reply with quote
Hi Bill
To you have a link to the thread. I couldn't find it on VAF.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill Gipson
Sent: February-14-10 7:52 AM
Subject: RE: Air Access on Wheel Farings
Bill Gipson
Subject: Air Access on Wheel Farings
Hi
Les
tsts4
PostPosted: Sun Feb 14, 2010 12:26 pm    Post subject: Re: Air Access on Wheel Farings Reply with quote
Here's the link to the thread on VAF:
http://www.vansairforce.com/community/showthread.php?t=51510&page=2&highlight=air+access
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
PostPosted: Sun Feb 14, 2010 4:11 pm    Post subject: Air Access on Wheel Farings Reply with quote
Les, do a search on VAF in the RV10 section and go back about 75 days with your search.  The thread in called adding air to RV10 tires.  Several ideas are described there.
Have you decided on your prop yet?
Bill
Subject: RE: RV10-List: Air Access on Wheel Farings
Date: Sun, 14 Feb 2010 08:54:21 -0700
.ExternalClass .ecxhmmessage P {padding-bottom:0px;padding-left:0px;padding-right:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-family:Verdana;font-size:10pt;} Hi Bill
Cheers
Les
Bill Gipson
Hi
Les
ttp://www.matronics.com/Navigator?RV10-List
ronics.com
ww.matronics.com/contribution
Lew Gallagher
PostPosted: Sun Feb 14, 2010 6:03 pm    Post subject: Re: Air Access on Wheel Farings Reply with quote
Hey Les,
I decided to 'Keep it simple" and went with these 2" nylon knockout plugs from Grainger:
http://www.grainger.com/Grainger/items/1EMR6?Pid=search
I just scuffed up the nylon and painted it with the same acrylic enamel as the plane -- so far it is sticking. I used an under 2" hole saw, then hand filed the pants to fit. I also used a heat gun to gently soften the "grip cleats" to bend them to grab tighter so they won't vibrate out.
It works well with the front wheel, but as others have noted, the mains valve stem points directly at the axel nut. I won't cut the main pants until he changes the tube at a later date. I like the idea of a spring loaded door with catch, but it looks clunky on certified planes and I like the slick look.
Later - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
partner14
PostPosted: Sun Feb 14, 2010 6:21 pm    Post subject: Air Access on Wheel Farings Reply with quote
To keep it real simple... just install "leak stop" type tubes, and ck the pressure twice a year (seasonally) when you ck your brakes. That's simple!
Don McDonald
--- On Sun, 2/14/10, Lew Gallagher <lewgall(at)charter.net> wrote:
Subject: Re: Air Access on Wheel Farings
Date: Sunday, February 14, 2010, 6:03 PM
--> RV10-List message posted by: "Lew Gallagher" <lewgall(at)charter.net (lewgall(at)charter.net)>
Hey Les,
Later - Lew
non-pilot
Painting done!
On with wiring and avionics.
http://forums.matronics.com/viewtopic.php?p=286469#286469
[b]httphttp://forums.matronics.com/" target=_blank>http://forums.matronics.com
Don A. McDonald
40636
David Shelton
PostPosted: Tue Feb 16, 2010 9:08 pm    Post subject: Re: Air Access on Wheel Farings Reply with quote
Hey Grumpy, thanks for the tip on the remote pressure sensors. What is the range on them?
I would imagine the castoring nose-wheel makes a flat or blown tire very serious. On a typical Cessna, you might be able to keep it on the runway, but I would imagine the RV-10 would take you for a ride. I like to keep a close eye on my tires and pressure. Anything that makes them easier to check will probably mean I'll check them more frequently.
