Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Thu Apr 20, 2006 7:42 am Post subject: Sensenich ground adj prop |
Does anyone have any experience with the Sensenich Carbon Fiber ground adjustable prop used on a Jabiru 3300 in a 601XL?
Sensenich has a 10% off sale thru the end of April if you order direct from the factory so I'd like to take advantage of the list's collective wisdom to help make a purchase decision.
Tim
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
p.mulwitz(at)worldnet.att Guest
Posted: Thu Apr 20, 2006 8:45 am Post subject: Sensenich ground adj prop |
I spoke with the guru at Sensenich last year about this new
product. I believe it has just been made available to customers
recently, so there is not much information floating around. You
might check with Pete at Jabiru since he was involved a little in the
product development.
My understanding is you can get it from 60 to 62 inches and there
might be an option to get a leading edge reinforcement installed at
the factory. My current plan is to order one in the 60 inch length
since this should allow full 3300 rpm use on the Jabiru
3300. According to the guy at Sensenich the 62 inch length is
designed for use to 3200 rpms. (I hope my memory is good on this
point, but I am sure you can confirm the facts with the authorities.)
Good luck,
Paul
XL wings
Quote: | Does anyone have any experience with the Sensenich Carbon Fiber
Tim
flybumtoo
Tim Juhl
Posted: Thu Apr 20, 2006 3:31 pm Post subject: Re: Sensenich ground adj prop |
Thanks. I talked to Pete earlier today and he said that there were at least a couple of Zenith owners flying behind the new prop. He had generally favorable comments about the prop when used with Jabiru aircraft and said that about half the Zenith folks buying Jab 3300's were opting for the new prop.
I was hoping there might be someone on the list who could share their first hand experiences.
Tim
CFII
Champ L16A flying
Tim Juhl
Posted: Thu Apr 20, 2006 3:49 pm Post subject: Re: Sensenich ground adj prop |
Oops! I forgot to mention some other info I got while talking with Sensenich - You might find their comments useful
"We have a 64" two blade propeller for the jabiru 3300 engine.
Propeller is rated at the same rating as the engine: 3300 intermittant,
2850 continuous.
In my opinion, the propeller is fine for 3000 continuous.
Now with the new economy tuning kit, most people with 3300 engines will stay below 2900 because fuel consumption rises by 2 gph at 3000 and above. For the month of april, our composite aircraft propellers are available direct from the factory at 10% off.
$1525 retail - $1375 april special cost includes all mounting hardware for propeller. Normal finish is all white, red tips and flat back face. Alternate solid colors are: grey and black with white or red tips. Includes nickel leading edge. Delivery usually runs 2-3 weeks."
Tim
CFII
Champ L16A flying
