zsmith3rd(at)earthlink.ne Guest
Posted: Thu Apr 20, 2006 4:13 am Post subject: More 701 brakes |
List --
The 17 feet of quarter-inch OD Nylon tubing supplied by ZAC for the brake lines was actually only 14 feet.
Either I move the gear forward, rudder pedals aft, or, get more tubing.
Question is: Which tubing in the Spruce catalog is the replacement, "Nylo-Seal" or "Nylaflow"?
Tubing on hand is Nylon and was made in Canada. It is marked as .170 ID and fits perfectly on the supplied brass "Poly-Flo" fittings.
Regards & Thanks,
Zed/701/R912/90+%/etc
JAPhillipsGA(at)aol.com Guest
Posted: Thu Apr 20, 2006 8:16 am Post subject: More 701 brakes |
Zed, I have the plastic tube brake lines on my XL. If I was building again I
would not install it and here is why. When I vigorously apply bakes I am
getting hard pressure, but the plane does not slow as readily as I believe it
should. I think (without any real proof) that some of the pressure is dissipated by
the general expansion of 14/17 feet of plastic lines and in effect reducing
that to the brake calibers. I fly and land my plane, but I have missed more
than a few turn offs because I simply rolled past them. And I am not happy about
short airports. If I was building or if I ever have to rebuild ( pray Lord I
never have to ) I would install steel lines. FWIW, Best regards, Bill of
Georgia
planejim(at)bellsouth.net Guest
Posted: Thu Apr 20, 2006 9:42 am Post subject: More 701 brakes |
Bill and List,
If your replace the "plastic" brake line use 5052 aluminun not steel. That's
what I put on my Midget Mustang I, 35 years ago, using Cleaveland brakes.
Those would put the Mustang on it's nose if you weren't carefull. I don't
think there is pressure loss at the brakes due to expansion or flexing of
the "plastic" line on our Zeniths. Rather I think it's just too small brake
pads on the Matco brakes, but I could be Wrong AGAIN! I'm replacing the pads
now on my 601HD after 500 hrs (over 700 landings). They sure are small. They
won't hold the plane still when checking ignition at 3850 RPM of my 80HP
Rotax eng. I agree with Bill that unless I really slow down on final and
make a nice very slow touchdown I roll past some turn-offs. All the more
reason to make nice slow controlled landings!
Jim Hoak
cffd(at)pgrb.com Guest
Posted: Thu Apr 20, 2006 10:44 am Post subject: More 701 brakes |
The geometry of the ZAC brakes is such that you don't get good mechanical
advantage. A lot has been said about this in the past. If you are not
"bottoming out" the master cylinder you are not losing braking power due to
expansion of brake lines.
Chuck D.
N701TX
randy(at)shadycreekoutlaw Guest
Posted: Thu Apr 20, 2006 11:11 am Post subject: More 701 brakes |
Seems logical to me... Since a liquid cannot be compressed, at some point
the lines would quit expanding and would either burst or apply more force to
the brake pads... As long as you have not "bottomed out" the master
cylinder yet...
Randy B.
N344RB
doug kandle
Posted: Thu Apr 20, 2006 11:57 am Post subject: More 701 brakes |
I found out that if you don't break in the pads as the instructions
state, they don't work very well. When I break in a new set of
linings I taxi 2 or 3 thousand feet with the brakes on. They get hot
and I see sparks coming off of the disks. But after they cool, they
work much better.
> believe
>> > it
>> > dissipated by
>> > reducing
lllanducci(at)tds.net Guest
Posted: Fri Apr 21, 2006 5:29 am Post subject: More 701 brakes |
As Doug Kandle eluded to, proper break-in of the brakes is essential. I
have an 801 and even at gross weight with Zenith-supplied plastic brake
lines I have no trouble stopping. Before the break-in I could not keep
the plane from creeping forward during 1900 rpm mag tests. The
polypropylene lines supplied by Zenith are very hard, unlike many other
plastic types. Another potential problem leading to insufficient
braking is the presence of some air in the brake lines.
Larry Landucci -- N801LL
