Bob Griffin
Joined: 22 Jan 2006 Posts: 34 Location: Slingerlands,NY
Posted: Fri Apr 21, 2006 2:43 am Post subject: wing tip drag |
Hi Jerry and gang, consider some research before redesigning Homers'
wing. That wing tip that you mentioned as causing extra drag may also be hindering
the high pressure from under the wing from comming up onto the low pressure
on top of the wing, therefor distroying lift on the main wing area.
Fly Safe
Bob Griffin
_________________ Fly Safe
Bob Griffin
Slingerlands, NY |
mustangsally(at)semo.net Guest
Posted: Fri Apr 21, 2006 2:56 am Post subject: wing tip drag |
I understand the reason it is there. I would think at cruise speeds the need
would minimize. I was thinking Vortex generators on both top and bottom at
the last rib may reduce this problem at lower speeds. I will probably leave
to factory specs. One concern I had with doing this would be losing aileron
area.
Jerry
