longg(at)pjm.com Guest
Posted: Thu Apr 01, 2010 7:09 am Post subject: SD-8 Sink Point |
My setup is based on Z13/8 and I've got an SD-8 which is wired per the
diagram back to the battery side of the contactor. That post has limited
threads available for the 2 thread safety margin I require. I would like
to determine if the SD8 output can be re-positioned.
Is there any issue with connecting the output from the SD8 to the
battery buss post instead of running it back to the battery side of the
solenoid which is exactly where the battery buss is coming from? Per the
diagram the output passes through a 10 amp shunt.
Glenn
Posted: Thu Apr 01, 2010 9:50 am Post subject: SD-8 Sink Point |
At 10:05 AM 4/1/2010, you wrote:
Certainly wires can be moved around in terms of which
ends connect to where . . . as long as the pathways
of copper are still contiguous.
Posted: Thu Apr 01, 2010 12:23 pm Post subject: SD-8 Sink Point |
Thanks Bob. Move it shall be.
Glenn E. Long
