stinis(at)cox.net Guest
Posted: Tue Apr 18, 2006 10:35 pm Post subject: oil cooler issues |
Have any of you experience high oil temp on your Grumman tigers (AA5B)
during the warm months? I live in Southern CA and just the other day it was
around 85-90 degrees and by the time I took off to climbing through 3,000ft
my oil temp was almost at redline (250 degrees). I recently bought the
aircraft. Since I've had it hasn't been hot lately, so the problem has been
masked.
To stop the high oil temp, I recently put an oversized oil cooler on it, and
no change. This particular aircraft has oversized scopes located under the
cowling and also has an exhaust speed faring. Do any of you think this
would have any factor that would make it worse than a stock grumman? I also
took the sending unit out and replaced it with a new one. I also put both
sending units in boiling water along with the gauges to see if there was
something wrong...but everything seems to be accurate. We also verified the
thermostat was opening as well. The funny thing is you would assume your
cylinder temps would rise....well they were around 360 degrees. The
particualar aircraft has an EI gauge which is helpful.
Someone recommended to cross the oil lines at the oil cooler. He said
sometimes they could be switched internally...but, I've never heard of that
before. Every Grumman I've seen is rigged the same way I have it. I also
have another grumman that flies better in the heat. The hottest I've see
the oil temp is around 200 degrees and it's a stock AA5B. It doesn't haven
any of the mods I mentioned before on the other. Right now, were all
scratching our heads as to why this aircraft is at least 40-60 degrees
warmer than the other grumman.
Any thoughts/suggestions?
Stephen
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?TeamGrumman-List |
GrummanDude
Posted: Tue Apr 18, 2006 11:05 pm Post subject: oil cooler issues |
In a message dated 4/18/06 11:36:50 PM, stinis(at)cox.net writes:
Quote: | To stop the high oil temp, I recently put an oversized oil cooler on it,
and
no change.=A0 This particular aircraft has oversized scopes located under=20the
cowling and also has an exhaust speed faring.=A0 Do any of you think this
would have any factor that would make it worse than a stock grumman?=A0 I=20also
thermostat was opening as well.=A0 The funny thing is you would assume your
cylinder temps would rise....well they were around 360 degrees.=A0=A0 The
I would look seriously at the baffles and baffle seals. Particularly the
ones behind the nose bowl.
Fly it up to Auburn and let's take a look at it. Or, when I go to get
Travis' plane at Fox, I could meet you there and look at it.
I flew out of Fox for 22 years and the highest oil temp I ever saw was 220.=20
Gary
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
FLYaDIVE(at)aol.com Guest
Posted: Wed Apr 19, 2006 2:57 am Post subject: oil cooler issues |
In a message dated 4/19/06 2:36:50 AM Eastern Daylight Time, stinis(at)cox.net
writes:
and
Quote: | no change. This particular aircraft has oversized scopes located under
the
Quote: | cowling and also has an exhaust speed faring. Do any of you think this
also
Quote: | took the sending unit out and replaced it with a new one. I also put both
the
Quote: | thermostat was opening as well. The funny thing is you would assume your
that
Quote: | before. Every Grumman I've seen is rigged the same way I have it. I also
haven
Quote: | any of the mods I mentioned before on the other. Right now, were all
Stephen
Stephen:
The good part is that a larger oil cooler is a good thing.
Swapping the oil lines does NOTHING! There is NOTHING to swap internally.
B.O.B.S.
But, from what you describe the problem sounds like your Vernatherm. Pull it
and inspect it ... You are looking for two things:
1 - WEAR MARKS - A wear ring on the shinny stainless steel seat. Yes, there
should be a small ring but not deep or uneven rings. Bring it to your A&P if
you are not familiar with what normal one looks like. Best way to check
function is to swap with a good one.
2 - There is an AD against older Vernatherms, to inspect the secureness of
the crimped end nut. Newer ones have a roll pin through the nut & shaft.
I would also check the quality of the ring lug connection on the temperature
sending unit. DO NOT OVER TIGHTEN! Use a new internal star washer.
Barry
"Chop'd Liver"
Posted: Wed Apr 19, 2006 8:53 pm Post subject: oil cooler issues |
Thanks all for your help and suggestions. We messed with the Vernatherm and
verified all baffling was good. We didn't see any issues upon inspection,
but I think taking it out and looking at it probably did something when it
was all back together. Climbing out at 70kts, 85 degrees outside
through 8500 ft. the oil temp reached 230 degrees at maximum. Upon level
flight, it would cruise around 215 degrees. Upon landing it was around 190
degrees. Does this seem normal?
Thanks again for your help.
Stephen
GrummanDude
Posted: Wed Apr 19, 2006 9:35 pm Post subject: oil cooler issues |
In a message dated 4/19/06 9:54:25 PM, stinis(at)cox.net writes:
Quote: | Climbing out at 70kts, 85 degrees outside
through 8500 ft. the oil temp reached 230 degrees at maximum.=A0 Upon level
flight, it would cruise around 215 degrees.=A0 Upon landing it was around=20190
degrees.=A0 Does this seem normal?
The oil temp, typically, never goes much over 180 to 190 degrees. I have a
digital oil temp sensor and my temp is typlically 180 to 181 under most
conditions.
Gary
AuCountry Aviation
Posted: Thu Apr 20, 2006 3:10 am Post subject: oil cooler issues |
In a message dated 4/20/06 12:54:25 AM Eastern Daylight Time, stinis(at)cox.net
writes:
190
Stephen
Stephen:
The oil temps do seem just a slight bit high. I don't care for the 230 on
climb or the 215 in cruise or even the 190 on decent.
You mentioned an EI gage, it sounded like the gage was for Cylinder Temps not
oil, does it also do Oil Temps?
What color is your oil?
How long does it take to turn BLACK?
What are the compression's on the cylinders?
Playing Doctor over the Internet is difficult. Ya loose out on all the
touch'y - feel'y stuff. At this point I t would really be helpfull to examine the
baffeling and associated air flow.
You said you looked at the Vernatherm, but you did not mention anything about
the ware marks. They are a huge giveaway to problems.
Barry
"Chop'd Liver"
Posted: Thu Apr 20, 2006 5:06 pm Post subject: oil cooler issues |
Gary,
What was your outside air temp where you operate. My information was at
full power at maximum climb....Trying to create a worse case scenario.
Sound like my temp is still too high. I don't know what else to do...maybe
your cowling might help?
Stephen
GrummanDude
Posted: Thu Apr 20, 2006 9:06 pm Post subject: oil cooler issues |
In a message dated 4/20/06 6:06:38 PM, stinis(at)cox.net writes:
Quote: |
What was your outside air temp where you operate.=A0 My information was at
Sound like my temp is still too high.=A0 I don't know what else to do...maybe
With an OAT of 100+ I run about 190 to 195 oil temp. Climbing to cooler air
helps.
Baffles and larger cooling ramp exits help a lot with high oil temp.
Gary
AuCountry Aviation
923te(at)cox.net Guest
Posted: Fri Apr 21, 2006 2:44 am Post subject: oil cooler issues |
Gary,
Sounds like a perfect time to tout some of the outstanding benefits of your
new cowling design:)
Ned
Quote: | With an OAT of 100+ I run about 190 to 195 oil temp. Climbing to cooler
air
helps.
Gary
GrummanDude
Posted: Fri Apr 21, 2006 10:22 am Post subject: oil cooler issues |
In a message dated 4/21/06 3:45:23 AM, 923te(at)cox.net writes:
Quote: | Sounds like a perfect time to tout some of the outstanding benefits of your
Ned
> With an OAT of 100+ I run about 190 to 195 oil temp.=A0=A0 Climbing to cooler
> air
> helps.
I thought that was obvious
AuCountry Aviation
Posted: Fri Apr 21, 2006 10:24 am Post subject: oil cooler issues |
Only to those on the list in the know:)
