Posted: Fri Apr 21, 2006 8:36 pm Post subject: What to do about stripped canopy screw holes? |
Some of the holes in my canopy frame for the screws holding the bubble are
stripped. Is there a good fix?
-- Craig
Posted: Sat Apr 22, 2006 6:07 am Post subject: What to do about stripped canopy screw holes? |
Craig,
I would suggest drilling clear thru so you can use a screw long enough
to go thru the opposite
side. Then stub the pointed end so you don't get caught on it. If that
isn't good, go with a recessed head machine screw
and cap-nut the screw as it comes out the other side.
Larry McFarland - 601HDS at www.macsmachine.com
-- Craig
jlatimer1(at)cox.net Guest
Posted: Sat Apr 22, 2006 7:16 am Post subject: What to do about stripped canopy screw holes? |
Graig,
You might try the next larger size screw on the stripped out holes.
Jerry
JAPhillipsGA(at)aol.com Guest
Posted: Sat Apr 22, 2006 7:47 am Post subject: What to do about stripped canopy screw holes? |
Craig, I don't know if this is the "approved' method, but I did one by
putting JB Weld in the hole and a little on the threads of the screw and re screwed
until it was set. Now I have not removed that screw so I am not sure I can,
but expect I won't have to unless the canopy has to be replaced then the screw
will be the least of worries. Best of luck, Bill of Georgia
tutuzulu(at)gmail.com Guest
Posted: Sat Apr 22, 2006 8:39 am Post subject: What to do about stripped canopy screw holes? |
If you use JBWeld, just wrap a single layer of plumber's Teflon tape
around the screw before inserting, tight so the threads are defined
thru the tape. You can then pack the JBWeld into the covered threads
and put it into the hole. I once made a bolt hole in a rock this way,
and it held strong!
Bob
BTW Bill, great meeting you at the BBQ. I still chuckle at the story
about the fuel flood!
Bob Miller
601HD N722Z
Charlottesville, Virginia
leogates(at)allvantage.co Guest
Posted: Sat Apr 22, 2006 9:28 am Post subject: What to do about stripped canopy screw holes? |
Craig,
If you go the JB Weld route, just put some Vaseline on the screw
threads. The JB Weld will not stick to the threads then and will make
perfect threaded holes. IMHO the Teflon tape method will work, but more
work.
Leo Gates
N601Z
-- Craig
