albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Thu Apr 08, 2010 4:08 pm Post subject: AEROSHELL OIL SPORT PLUS 2 |
Hi Guys,
Anyone know what ratio this oil can be mixed at and where a person can buy it in Alberta?
Tony
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
Richard Pike
Posted: Thu Apr 08, 2010 7:50 pm Post subject: Re: AEROSHELL OIL SPORT PLUS 2 |
No, but I looked up the price, and you can get Phillips Injex for half that much. I have been using Injex since 1983 for over 1500 hours of 2 stroke time, and have had zero problems. And probably every snowmobile dealer in Alberta has it in stock.
Richard Pike
MKIII N420P (420ldPoops)
Thom Riddle
Posted: Fri Apr 09, 2010 4:36 am Post subject: Re: AEROSHELL OIL SPORT PLUS 2 |
Richard,
I no longer have a 2-stroke but am curious if you used Phillips Injex in both air-cooled and the 582 engines, lo these many years.
I still have a few quarts of the (pre-aeroshell) Pennzoil 2-stroke for air-cooled oil in my lubricants cabinet.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Richard Pike
Posted: Fri Apr 09, 2010 6:02 am Post subject: Re: AEROSHELL OIL SPORT PLUS 2 |
| Thom Riddle wrote: | Richard,
I still have a few quarts of the (pre-aeroshell) Pennzoil 2-stroke for air-cooled oil in my lubricants cabinet. |
Yep. Started with the Rotax 277 on the Hummer in 1983, used it in the 532 in the J-6, the 532 in the MKIII, and now the 582 in the MKIII. Doing an annual now, the dental mirror shows a faint dusting of carbon on top of the piston, nothing on the underside of the head, a little in the corners of the exhaust manifold, and the rings are free. 582 is right at 200 hours.
Also, it does not leave clumps of sticky black carbon on the tail like Pennzoil did. (Tried it for one summer, went back to Injex)
Richard Pike
Thom Riddle
albertakolbmk3
Posted: Fri Apr 09, 2010 4:24 pm Post subject: Re: AEROSHELL OIL SPORT PLUS 2 |
What ratio is the phillips good for?
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
Richard Pike
Posted: Fri Apr 09, 2010 6:01 pm Post subject: Re: AEROSHELL OIL SPORT PLUS 2 |
| albertakolbmk3 wrote: | | What ratio is the phillips good for? |
I premixed at 50:1 in former years, and now with the 582, just let the oil pump do it's thing.
Richard Pike
