CJohnston(at)popsound.com Guest
Posted: Sun Apr 23, 2006 8:02 am Post subject: .311 drill bit? (or 7.9mm?) |
hey all -
there's a hole that needs to be drilled in the gear mount with a .311 drill bit. where do you get this? or 7.9mm. does this measurement correlate with a numbered drill bit? help.
cj
#40410
fuse
www.perfectlygoodairplane.net
rvbuilder(at)sausen.net Guest
Posted: Sun Apr 23, 2006 8:46 am Post subject: .311 drill bit? (or 7.9mm?) |
This has been discussed at length before. Please check the archives and then follow up with any additional questions.
Michael Sausen
-10 #352 fuselage
DO NOT ARCHIVE
ichelva(at)netspace.net.a Guest
Posted: Sun Apr 23, 2006 8:47 am Post subject: .311 drill bit? (or 7.9mm?) |
Avery Tools sell an undersized 5/16 reamer which is .3110 inch in diameter.
Works nicely for a snug fit of the landing gear bolt
Indran Chelvanayagam
mark(at)macomb.com Guest
Posted: Sun Apr 23, 2006 9:00 am Post subject: .311 drill bit? (or 7.9mm?) |
Chris,
You can buy one from McMaster-Carr. http://www.mcmaster.com/ items
2958A126 and 30565A304 seem to fit the bill. Enco is another good source
for drills and things but their page is down this morning.
There was some chatter several months ago concerning this size of bit.
Someone proposed one builder buying a bit and passing it along to the
next builder who needed it. Maybe that has happened. I intend to order a
couple next time I need something from McMaster-Carr. The bits only cost
$4.00 but the shipping will probably double the price.
Mark
Chris Johnston wrote:
| Quote: | hey all -
cj
#40410
fuse
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.385 / Virus Database: 268.4.5/322 - Release Date: 4/22/2006
jesse(at)itecusa.org Guest
Posted: Sun Apr 23, 2006 9:38 am Post subject: .311 drill bit? (or 7.9mm?) |
We, as I believe Van's says is fine, used a 5/16 reemer and did it very
carefully. The bolt still fit very snug for us, just make sure that you get
a clean 5/16 and not oversize it.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
ninepapa(at)bendbroadband Guest
Posted: Sun Apr 23, 2006 11:18 am Post subject: .311 drill bit? (or 7.9mm?) |
Chris
All number drills are too small
No letter drills are close.
7.9mm is .311024", thats pretty close.
John
40359
Tim(at)MyRV10.com Guest
Posted: Sun Apr 23, 2006 5:39 pm Post subject: .311 drill bit? (or 7.9mm?) |
I had a friend with a .311 reamer in his machine supplies. I think
you could easily get one at a local machine tool supply house.
I would strongly suggest going with the proper size reamer
and not just a drill bit though. I reamed mine and must have put
just the slightest amount of crookedness to the hole, and now I
have just the smallest bit of play in one gear leg. I plan to
pull the seat and add some type of gap-fill loctite to the
bolt to ensure that it doesn't have any play in it, as play
will only get worse over time.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
