Albert Gardner
Posted: Sun Apr 25, 2010 5:52 pm Post subject: Vixen File |
[quote]A Vixen file is the ideal tool for making those little spacers Van uses here and there. Since the end needs to be perpendicular to the axis, you clamp the Vizen file down on your drill press table, chuck the piece of tubing in the drill press chuck and lower it down onto the Vixen file. After that end is finished, measure it for length and reverse the piece in the chuck taking off the necessary amout to get the proper length. Albert GardnerN991RVYuma, AZ [b]
_________________ RV-9A N872RV
RV-10 N991RV |
MauleDriver(at)nc.rr.com Guest
Posted: Mon Apr 26, 2010 6:51 am Post subject: Vixen File |
Nice! Wish I knew/thought of that before now.
thanks.
Albert Gardner wrote:
| Quote: | *A Vixen file is the ideal tool for making those little spacers Van uses here and there. Since the end needs to be perpendicular to the axis, you clamp the Vizen file down on your drill press table, chuck the piece of tubing in the drill press chuck and lower it down onto the Vixen file. After that end is finished, measure it for length and reverse the piece in the chuck taking off the necessary amout to get the proper length. *
*Albert Gardner*
*N991RV*
*Yuma, AZ*
Posted: Mon Apr 26, 2010 8:02 am Post subject: Vixen File |
Me too!
| Quote: | Date: Mon, 26 Apr 2010 10:21:34 -0400
Subject: Re: Vixen File
--> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com>
thanks.
> *Albert Gardner*
> *N991RV*
> *Yuma, AZ*
