lgold(at)quantum-associat Guest
Posted: Wed Apr 28, 2010 8:50 am Post subject: 912 "cylinder type" |
I had my engine oil analyzed by Aviation Laboratories. They came back and said they can’t tell if everything is normal until they know what “cylinder type” is in my 912ULS.
I don’t know what “cylinder type” comes in a 912ULS and didn’t know different cylinder types were available. Can someone clue me in here?
Les
rickofudall
Posted: Thu Apr 29, 2010 3:15 am Post subject: 912 "cylinder type" |
Sounds like they're not used to dealing with the 912. What they probably see is an elevated iron level from the gear box and they're thinking in terms of the iron cylinders of a Lycosaur.The 912 uses a process that deposits a hard coating (Nikasil) on an aluminum cylinder. I doesn't wear a lot, or shouldn't at least.
Rick Girard
On Wed, Apr 28, 2010 at 11:27 AM, Les Goldner <lgold(at)quantum-associates.com (lgold(at)quantum-associates.com)> wrote:
Les
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
tp://forums.matronics.com
hgmckay
Posted: Thu Apr 29, 2010 4:49 am Post subject: 912 "cylinder type" |
Les, I think what they need to know is if the engine cylinder walls are ordinary steel, ceramic, stainless lined, ect.
For the Rotax Engine 912 series the cylinder is steel.
Hugh McKay
From: Les Goldner (lgold(at)quantum-associates.com)
Sent: Wednesday, April 28, 2010 12:27 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com) ; rotax(at)yahoogroups.com (rotax(at)yahoogroups.com)
Subject: 912 "cylinder type"
Les
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
rickofudall
Posted: Thu Apr 29, 2010 3:11 pm Post subject: 912 "cylinder type" |
Hugh, The cylinders of the 912 are most definitely NOT steel. See the heavy maintenance manual if you don't believe me.
Rick Girard
On Wed, Apr 28, 2010 at 1:28 PM, Hugh McKay <hgmckay(at)bellsouth.net (hgmckay(at)bellsouth.net)> wrote:
[quote] Les, I think what they need to know is if the engine cylinder walls are ordinary steel, ceramic, stainless lined, ect.
Hugh McKay
Les
hgmckay
Posted: Thu Apr 29, 2010 6:13 pm Post subject: 912 "cylinder type" |
Rick,
Your right! Stupid me.
Hugh
Sent: Thursday, April 29, 2010 12:11 PM
Subject: Re: 912 "cylinder type"
Rick Girard
Hugh McKay
Les
Roger Lee
Posted: Mon May 03, 2010 4:59 pm Post subject: Re: 912 |
The Rotax cylinders are a nickel silicone combination “called Gilnasil” its a process that is done by many companies.... all based on a matrix of nickel with small particles of silicon-carbide.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
