Jim Ballenger
Joined: 12 Jan 2006 Posts: 18 Location: Virginia Beach, Virginia
Posted: Sun Apr 23, 2006 2:58 am Post subject: ETHANOL AS A FUEL ADDITIVE |
Hello
In my part of the country, Hampton Roads in Virgina, they are switching from MTBE to ethanol as an additive in the fuel. Do any of you have any experience using this kind of fuel?
Jim
MK3X
Virginia Beach, VA
Posted: Sun Apr 23, 2006 5:19 am Post subject: ETHANOL AS A FUEL ADDITIVE |
Jim, there is a May deadline for MTBE to be out of the mogas so
ethanol will be
in all our supplies soon. Two negative factors are reduced power
output, and
storage problems. It is problematic for the transportation of gas in
that
the ethanol cannot, for some reason, be added before pipeline
transmission,
but has to be mixed at destination.
We should all be observant of our fuel properties this summer.
-BB
On 23, Apr 2006, at 6:58 AM, Jim Ballenger wrote:
Hello
Jim
MK3X
Virginia Beach, VA
http://forums.matronics.com/viewtopic.php?p=30131#30131
Cat36Fly(at)AOL.COM Guest
Posted: Sun Apr 23, 2006 12:07 pm Post subject: ETHANOL AS A FUEL ADDITIVE |
Jim,
They are changing over here in Delaware as we speak. My understanding is
that Rotax says "no ethanol." GA pilots with auto gas STC's are in the same boat.
Larry Tasker
MKlllx 582
N615RT
Jim Baker
Posted: Sun Apr 23, 2006 4:26 pm Post subject: ETHANOL AS A FUEL ADDITIVE |
| Quote: | It is problematic for the transportation of gas in
that
transmission,
When they send the various grades of gas down the pipeline, I'll give you one
guess what they separate the grades with.......
Since ethanol is hygroscopic, that explains that.
Jim Baker
580.788.2779
Elmore City, OK
ul15rhb(at)juno.com Guest
Posted: Sun Apr 23, 2006 5:26 pm Post subject: ETHANOL AS A FUEL ADDITIVE |
Jim, in Minnesota ethanol has been in the gas for many years and I have used it in my Rotax without any problems. Some stations offer ethanol-free gas for 20 cents/gallon over regular. I chose to use the ethanol-free gas.
Ralph
-- "Jim Ballenger" <ulpilot(at)cavtel.net> wrote:
Hello
Jim
MK3X
Virginia Beach, VA
Try Juno Platinum for Free! Then, only $9.95/month!
Dave Bigelow
Joined: 29 Jan 2006 Posts: 103 Location: Kamuela, Hawaii
Posted: Mon Apr 24, 2006 1:04 am Post subject: Re: ETHANOL AS A FUEL ADDITIVE |
Here in Hawaii, all fuel (except avaiation) sold in the state is mandated by law to contain up to 10% ethanol (E-10). There is no source of standard gasoline available in the State.
I did quite a bit of research on the subject. It's not a big deal with four stroke engines built within the last ten years or so. Earlier engines may have deterioration of fuel system components, if operated with E-10.
It's a different story for two stroke engines. Rotax has a service bulletin out that cautions against using gasoline with more than 5% ethanol. I called Lockwood Aviation and spoke to one of their techs. The problem is that the ethanol eats up the crankcase seals over time. They recommend using 100 octane low lead aviation gasoline if standard auto gas is not available.
There can be problems with premix if E-10 is used. In general, synthetic oils don't mix well with an ethanol/gas blend. A gallon of E-10 contains less energy than a gallon of gasoline, and also runs slightly leaner with the same jetting than gasoline. Also, E-10 can absorb much more water than standard gasoline.
_________________ Dave Bigelow
Kamuela, Hawaii
FS2, HKS 700E |
Jim Ballenger
Posted: Mon Apr 24, 2006 11:31 am Post subject: Re: ETHANOL AS A FUEL ADDITIVE |
Thanks to all for the feedback on the ethanol.
Jim
MK3X
Virginia Beach, VA
