bcondrey
Posted: Sat May 08, 2010 7:42 am Post subject: OH Vent Controller Report |
One of the issues with overhead consoles fed via a pair of NACA vents is that you get a LOT of air at relatively high pressure. The downside is that the air coming out the individual vents in the console is at high pressure so for a comfortable amount of air you wind up with them almost closed. I had been considering installing butterfly valves in the feed lines but during a discussion with Geoff Combs (http://www.aerosportproducts.com/) I found out that he already had a solution in mind. He sent me a prototype of his OH console vent controller and it's GREAT! It allows you to remotely adjust the air flow into the OH console and the end result is that you have the interior vents at low pressure but providing a high volume of air to the passengers.
Install is simple - it has a couple of 2" segments with butterfly valves in them controlled by a single servo. Just connect those into your air feed. There's a very small control module (about 3/4" x 2") with a potentiometer on it the connects to the servo via supplied 3 conductor wire. It also needs power/ground to the control module. I installed the control module in my OH console and supplied power from an inline fuse protected wire off the switched side of the battery contactor so wire run was simple and didn't require anything in the panel. Total install time was a couple hours including removal/reinstall of the baggage bulkhead.
If you've got an OH console you can relate to the high air pressure issue - this is a very elegant solution.
In the spirit of full disclosure: except for having received one of the prototype units for testing I have no financial interest in Geoff's company or the product.
Bob
RV-10 N442PM
tsts4
Posted: Sat May 08, 2010 7:51 am Post subject: Re: OH Vent Controller Report |
Bob (and anyone else flying with an OH console), besides using Geoff's controller, what are the pros or cons with just going with one NACA vent vs two to feed the OH.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
Albert Gardner
Posted: Sat May 08, 2010 8:53 am Post subject: OH Vent Controller Report |
I have 2 NACA feeds to my OH console and it is just fine. This is the HOT
part of the country with mucho days of +100 temps. My summertime flying at
low altitudes has all vents wide open and wishing for more. I even use one
of those tent coolers in the back seat to help out while on the ground.
Albert Gardner
N991RV
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
ricksked(at)cox.net Guest
I have two vents, one would be plenty but I'm not sure how good one
would be during taxi. The airflow on the ground with two is great. In
the air I need to keep the vent pointed away from my mic due to the
velocity of the air even turned way down
Rick
On May 8, 2010, at 8:51 AM, "tsts4" <tsts4(at)verizon.net> wrote:
Todd Stovall
728TT (reserved)
RV-10 Empacone, Wings
http://forums.matronics.com/viewtopic.php?p=297111#297111
rleffler
Posted: Sat May 08, 2010 9:06 am Post subject: OH Vent Controller Report |
Con: One side of the aircraft being a few ounces lighter than the other. :^)
I thought about this for awhile and just put them both in. I don't think
there is any particular advantage or disadvantage.
_________________ Bob Leffler
N410BL - Phase I
speckter(at)comcast.net Guest
Posted: Sat May 08, 2010 11:54 am Post subject: OH Vent Controller Report |
You know why they don't send donkeys to college? No one likes a smart
donkey!!
Sorry Bob, I just couldn't resist.
Gary Specketer
bcondrey
Posted: Sat May 08, 2010 3:50 pm Post subject: Re: OH Vent Controller Report |
In response to the question about whether one NACA vent would be sufficient: I don't think anybody has tested that. The original (Accuracy Avionics) method had a single 2" vent in the tail fairing - kind of a smaller version of the 727 look. When a few of us decided that we didn't want that, a NACA vent approach was taken but early adopters didn't know 1) if there would be sufficient flow with a single vent, and 2) whether the left or right side would be better placement.
I was actually going to figure this out by blocking off one and a time and test flying but Geoff's controller negated the need.
Bob
RV-10 N442PM
robin(at)PaintTheWeb.com Guest
Posted: Sat May 08, 2010 4:38 pm Post subject: OH Vent Controller Report |
I was one of the semi-early installers / flying -10's with the AA OH
Console. I asked the same question over 2 years ago with no definite
answer. After some consideration I placed both NACA vents in for my
system. Once flying I covered one vent to test and found that much less
air was available for ground ops and slightly less pleasure but still
acceptable amounts were available in flight. Please note in reflecting
back on my test observation I am sure I had both back vents closed so
please take that into consideration when making your decision. I would
place both NACA vents in again if I were in the position to decide. I do
plan on adding the electrically controlled valve during my condition
inspection (once I find out the pricing).
Good luck,
Robin
gengrumpy(at)aol.com Guest
Posted: Sat May 08, 2010 6:23 pm Post subject: OH Vent Controller Report |
I'm one of Tony's first customers. I did not use NACA vents but made
a couple of small "dog ears" that I placed under the horizontal tail
on both sides.
Works pretty good, and in the winter I plug one or both of them up to
keep air flow to a minimum into the console when OAT is really cold.
Not sure it would be so easy to plug up a NACA vent that goes straight
into the flex tubing feeding the console.
It is nice to have the overhead vents so you can turn down the NACA
side vents as needed.
My 2 cents.
grumpy
N184JM
On May 8, 2010, at 6:50 PM, bcondrey wrote:
placement.
Bob
RV-10 N442PM
http://forums.matronics.com/viewtopic.php?p=297136#297136
drfred(at)suddenlinkmail. Guest
Posted: Sat May 08, 2010 6:35 pm Post subject: OH Vent Controller Report |
I have the Accuracy Avionics overhead and two Naca inlets. I have a
CO monitor and have noted that occasionally, I will get a warning when
flying low and with the overhead vents open. Seems to only happen with
a crosswind . I wonder if the corkscrew airflow is putting some of the
exhaust in the right NACA duct. Will try and block off each side and
see if it helps or recurrs.
I do like the overhead airflow. It is nice on the hot Texas days.
Dr Fred
515 FW
tsts4 wrote:
Todd Stovall
728TT (reserved)
