Carlos Sa
Posted: Mon Apr 24, 2006 5:48 pm Post subject: holes, drill bits, reamers and bolts |
Hello, fellow listers
Once again, I have managed to create problems where no one has created before!
I got reamers of the proper sizes (5/16" and 3/8") to drill the wing attach plates (CH601-HD),
and the alphabetic size drills to go with them (N and U).
So, tonight I made some holes in some scrap material, for practice.
I expected the bolt to fit very tightly, but nope! They go through easily. Not too loose, but not
tight. Same with both sizes.
Then, for comparison, I made a hole with a regular 3/8" drill bit, and the results were similar,
if not a bit tighter!
Am I doing something wrong, or is the difference supposed to be that subtle?
Here's how I made the holes: started with small drill bit and replaced it with a large one. Drill
hole and repeat.
Below is the sequence for each final size.
Hole for AN5 (5/16"): 1/8", 13/64", 1/4", then N.
Hole for AN6 (3/8"): 1/8", 13/64", 1/4", N, then U.
Hole for AN6 (3/8"), no reamer: 1/8", 3/64", 1/4", N then 3/8"
Note that the material was clamped to the drill press table all the time. I did have to lower the
table one or two inches in order to mount the reamers. This is the only thing I can think could
have thrown the process off track.
One more question: to avoid the adjustment step, I could cut the reamer's shank. Does anyone see
a problem with this?
Thanks in advance for your toughts / comments / blank stares.
Carlos
CH601-HD, plans
working on a concept of infinity applied to time.
Lche-vitrine ou lche-cran ?
magasinage.yahoo.ca
| - The Matronics Zenith-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ CH601-HD, plans
Montreal, Canada |
cgalley(at)qcbc.org Guest
Posted: Mon Apr 24, 2006 7:29 pm Post subject: holes, drill bits, reamers and bolts |
Did you mike the bolts?
rjscep(at)yahoo.com Guest
Quote: | Carlos, there is another way. Try using close
tolerence AN bolts. They may solve your problem. Bob
and U).
hole and repeat.
then 3/8"
blank stares.
Carlos
CH601-HD, plans
magasinage.yahoo.ca
browse
Subscriptions page,
FAQ,
Admin.
If you have a standard chucking reamer of a nominal size, an AN bolt is
always a couple of thousands smaller. You can get precision ground aircraft
bolts. If you can find them as surplus they are reasonable.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
grs-pms(at)comcast.net Guest
Posted: Mon Apr 24, 2006 8:44 pm Post subject: holes, drill bits, reamers and bolts |
Carlos:
For a 3/8 diameter AN6 bolt, the max diameter is .374 and the min is only
.371. Perhaps you can select AN6 bolts that run toward the maximum
diameter. The corresponding close tolerance bolt, AN 176, has a max
diameter slightly greater at .3742 and the minimum is .3737. For a 5/16 AN5
bolt you could substitute the close tolerance AN175. Again the minimum
diameter is larger for the close tolerance bolt. Bolt strength is
equivalent in each case.
George
flybumtoo
n801bh(at)netzero.com Guest
Posted: Mon Apr 24, 2006 11:20 pm Post subject: holes, drill bits, reamers and bolts |
The easiest way to is mic the bolts, get an avaerage size of the shank , then order a reamer that size. MSC, Mc Master and other tool houses sell all sizes of reamers in .001 increments at very reasonable prices. For instance, you have bolts that measure .373, round up the amount that size needed for the job and order a .372 reamer for 8 bucks or so.
Ben Haas
N801BH
www.haaspowerair.com
-- "Dan Ribb" <dan(at)danribb.com> wrote:
Check out this article. It really helped me out - especially the last 3
paragraphs.
http://www3.sympatico.ca/fhofmann/art_round_hole.html
I found this helpful too.
http://exp-aircraft.com/library/alexande/hardware.html
- Dan
Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Tue Apr 25, 2006 4:18 am Post subject: Re: holes, drill bits, reamers and bolts |
Hi Carlos
Depending on the setup and the tool, you may sometimes get a hole bigger than the drill. However, that does not matter as long as the hole is still smaller than the reamer that you are about to put in it. Check the hole size after the drill is done. If it is O.K. put the reamer through. Always run your reamers a lot slower than your drill (rpm). If the reamer cuts, the hole WILL be the same diameter as the reamer.
Your chuck may not be running true. You should have a clamp on the part for safety. I suggest you do not cut the reamer down. The extra length allows the reamer to flex and follow the drilled hole. A shorter reamer is stronger and if there is runout it will tend to cut oversize like it was a boring bar. Hope this helps..........Geoff.
