bhughes(at)qnsi.net Guest
Posted: Mon Apr 24, 2006 10:36 am Post subject: Fiber Glass thickness at Door Bottoms. |
After sanding the doors into place I have almost no material left on the bottom of the doors where they were glued together. I have some separations that will require a couple of layers of glass to re-bond. I am well inside the bottom scribe lines. Did anyone else need to sand this far to make the doors fit. I have been looking at it for a week now and I do not see where I could have done anything different except maybe take more off the cabin top at the base of the doors.
Bobby
40116
coop85(at)bellsouth.net Guest
Posted: Mon Apr 24, 2006 2:36 pm Post subject: Fiber Glass thickness at Door Bottoms. |
Bobby,
I too had to cut well inside the scribe lines so you may not have a problem there as long as the door fits well. I commented to my self several times that the scribe lines weren’t all that accurate.
As for the separations you might want to try and just inject some resin in the gaps rather than add glass which will be tough to get as smooth as the door itself due to the extra thickness.
Marcus
40286
Posted: Mon Apr 24, 2006 3:58 pm Post subject: Fiber Glass thickness at Door Bottoms. |
Marcus,
Visited by another RV10 builder this afternoon. He quickly pointed out my problem. The start of the problem was that I did not lower the cabin top enough on the fuse. I left it up about 1/8" higher than it needed to be. So guess where my missing 1/8" went. Not a big deal but I will need to add it back to the bottom of the door and sand down and re-bevel the bottom door frame. This will also give me the bottom edge needed to place the door seal on the bottom of the door.
Bobby
(fiberglass - love/ hate thing)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Marcus Cooper
Sent: Monday, April 24, 2006 5:34 PM
Subject: RE: Fiber Glass thickness at Door Bottoms.
Bobby,
Marcus
40286
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bobby J. Hughes
Sent: Monday, April 24, 2006 2:35 PM
Subject: Fiber Glass thickness at Door Bottoms.
Bobby
40116
capsteve
Joined: 09 Jan 2006 Posts: 111 Location: NIAGARA FALLS NY
Posted: Mon Apr 24, 2006 10:37 pm Post subject: Fiber Glass thickness at Door Bottoms. |
Bob, I took an epoxy syringe from west marine and drilled small holes above the joint and pumped in thickened epoxy, then just filled the holes (#30). It Ended up making a fillet inside the door frame. I also pumped in expanding urethane foam into the larger cavities to insulate and glue. Just be careful not to guppy the thing……..the expanding foam can easily deform the door. It didn’t add much weight but it really seems to give the door a more solid feel…..
Fwiw
Steve dinieri
40205
rick.conti(at)boeing.com Guest
Posted: Tue Apr 25, 2006 6:48 am Post subject: Fiber Glass thickness at Door Bottoms. |
Bobby,
Please help me understand, as I have trimmed my top but have not fitted the doors. The doors are hinged on the roof and close (it appears) on the bottom of the roof. I don’t understand how not having the roof flush to on the fuselage would effect the doors. It appears they can be fitted even if the roof were sitting on a bench.
Thank You
Rick Conti
Senior Engineering Manager
The Boeing Company
office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
Sent: Monday, April 24, 2006 7:59 PM
Marcus,
Bobby
Bobby,
Marcus
40286
Tim(at)MyRV10.com Guest
Posted: Tue Apr 25, 2006 7:25 am Post subject: Fiber Glass thickness at Door Bottoms. |
Rick,
This is my guess after reading that and trying to remember that step...
The door is positioned on the airframe using holes in tabs on the
outside edges of the doors in a couple spots. They go into rivet
holes in the fuselage.
So, if you don't trim the "threshold" area of the door (the underside
of it) enough, then it won't sit down on the fuselage as far as
it should. You would also likely notice that the seam of the canopy
to aluminum under the rear windows would tend to have a gap and
sit high, although it seems like it's a bit normal to have a small
amount more gap near the doors than at the rear of the canopy.
At any rate, if the canopy is high, but the doors are referenced to
the fuselage, then you'd end up with the doors in slightly the wrong
place on the canopy top.
Conti, Rick wrote:
[quote] Bobby,
Thank You
*Rick Conti*
*/Senior Engineering Manager/*
*/The Boeing Company/*
* office: 703 - 414 - 6141*
*blackberry: 571 - 215 - 6134*
*From:* Bobby J. Hughes [mailto:bhughes(at)qnsi.net]
*Sent:* Monday, April 24, 2006 7:59 PM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Fiber Glass thickness at Door Bottoms.
Marcus,
Bobby
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Marcus Cooper
*Sent:* Monday, April 24, 2006 5:34 PM
Bobby,
Marcus
40286
Posted: Tue Apr 25, 2006 7:33 am Post subject: Fiber Glass thickness at Door Bottoms. |
Rick,
Since you put it that way it does not make since. My top sitting 1/8" higher does not effect the door bottom fit. It made since yesterday ...... But removing material from the "top" of the bottom door frame will still be required in my case. Thanks for the correction.
Bobby
40116
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Conti, Rick
Sent: Tuesday, April 25, 2006 9:46 AM
Bobby,
Thank You
Rick Conti
The Boeing Company
Marcus,
Bobby
Bobby,
Marcus
40286
Bobby
40116
Posted: Tue Apr 25, 2006 7:58 am Post subject: Fiber Glass thickness at Door Bottoms. |
This is not at all a precise measurement, but I'd guess that my
thickness of the threshold area of the door was about 3/16 to
1/4" thick at most. When you sand the bottom "lip" of the door
frame area off, it should be pretty thin and sit flat on the
aluminum door entry area.
Bobby J. Hughes wrote:
[quote] Rick,
Bobby
40116
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Conti, Rick
*Sent:* Tuesday, April 25, 2006 9:46 AM
Bobby,
Thank You
*Rick Conti*
Marcus,
Bobby
Bobby,
Marcus
40286
Posted: Tue Apr 25, 2006 8:32 am Post subject: Fiber Glass thickness at Door Bottoms. |
I am guessing mine is about 1/4". But the other builder who looked at it
said it was much thicker than his.
Bobby
Posted: Tue Apr 25, 2006 9:25 am Post subject: Fiber Glass thickness at Door Bottoms. |
Got it, thanks.
DO NOT ARCHIVE
Thank You
Rick Conti
The Boeing Company
