hanslab
Posted: Wed May 26, 2010 7:27 am Post subject: Jabiru on a Kitfox |
I'm currently buying a Classic IV with a Jabiru engine mount (haven't got it yet for it is still in the States - looking for a way to get it overhere).
Does any of you have any experience on that combination?
Any information would be great, for there isn't any from Jabiru Australia nor SkyCraft's
tx in advance,
hans Labruyere
Classic IV (building)
the Netherlands
hans.labruyere(at)gmail.com
bw12345(at)sbcglobal.net Guest
Posted: Wed May 26, 2010 9:25 am Post subject: Jabiru on a Kitfox |
Have a 2200 on a classic four. Cruise nicely at 80mph. Will go above 100 mph. At 70-80mph 2 3/4 US gal hr.Lift off one person on pavement about 200 feet. Less in winter.Fun plane but be alert on landings.
BOB
--- On Wed, 5/26/10, hanslab <hans.labruyere(at)gmail.com> wrote:
Subject: Jabiru on a Kitfox
Date: Wednesday, May 26, 2010, 11:27 AM
poasttown(at)yahoo.com Guest
Posted: Wed May 26, 2010 12:09 pm Post subject: Jabiru on a Kitfox |
I also have the Jabiru 2200 on a Mod. four. I get about the same performance as I did with the Rotax 582 with just a bit higher speeds, around 80-85 mph cruise. The largest difference was going from a three blade prop on the 582 to a two blade prop on the Jabiru. When I pulled the power back on the 582 I would really slow down. With the jabiru the plane seems to want to float much more.
Mike Chaney
--- On Wed, 5/26/10, Robert Rivard <bw12345(at)sbcglobal.net> wrote:
Subject: Re: Jabiru on a Kitfox
Date: Wednesday, May 26, 2010, 1:25 PM
BOB
wb2ssj(at)frontiernet.net Guest
Posted: Wed May 26, 2010 12:43 pm Post subject: Jabiru on a Kitfox |
You will love the combination, have one and my freind has one also. Good
luck Tex
Lynn Matteson
Posted: Wed May 26, 2010 12:59 pm Post subject: Jabiru on a Kitfox |
Hans-
I'll just post numbers from a flight today with my Jabi-fox/ Kit-a-roo.
Today I answered a guy (privately) who asked about the TBI on my
plane and if I had to constantly adjust it, or could I just set it to
lean of peak (or just an economy setting) and forget it.
So for kicks, I went for a 2.4 hour, 234 mile flight and just set the
engine to where it ran well, and well lean of peak. As you can see, I
averaged about 100 mph, went around a larger than 50-miles-per-side
square, and the fuel flow meter looked like it was stuck on 2.9 gph,
upping 4 or 5 times to 3.0, and about the same number of dips to 2.8.
This is using a Rotec TBI, but similar numbers have been reported
using the Bing carb that comes with the engine. The benefit of using
the TBI is to be able to set the mixture "lean of peak EGT", which
you'll hear more about as the years go on and people become educated
about it.
Lynn Matteson
Jabiru 2200, #2062, 954.7 hrs (since 3-27-2006)
Countdown to 1000 hrs~45.3 to go(59 days to go)
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying (and learning)
On May 26, 2010, at 11:27 AM, hanslab wrote:
tx in advance,
hans Labruyere
the Netherlands
http://forums.matronics.com/viewtopic.php?p=298934#298934
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
larry huntley
Posted: Wed May 26, 2010 5:19 pm Post subject: Jabiru on a Kitfox |
Hey Tex,
Been wondering where you were! Larry
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Posted: Wed May 26, 2010 5:32 pm Post subject: Jabiru on a Kitfox |
Hi Larry, I am always lurking in the background. Tex
Michel
Posted: Wed May 26, 2010 11:47 pm Post subject: Re: Jabiru on a Kitfox |
Hello Hans,
I have changed my 582 for a Jabiru 2200 a few years ago, on my Kitfox III. Since then, I have been flying roughly 350 problem-free hours. I like the engine although I am sure Rotax engines are good too!
Groeten uit Noorwegen
Michel Verheughe
Norway
_________________ Kitfox 3 - Jabiru 2200 |
