N1BZRich(at)AOL.COM Guest
Posted: Mon May 31, 2010 7:42 pm Post subject: Nose wheel shimmy |
If you suspect a nose wheel shimmy, there might be an easy fix by just tightening the bolts that hold the nylon blocks together around the nose gear leg. Sometimes, that is all it takes. If that does not work, probably then next step is to disassemble the unit so that you can sand a very small amount off the nylon blocks where they fit together. By doing this they will then be able clamp a little harder on the nose gear leg.
To check the nose wheel for proper movement, have someone raise the nose wheel by pushing down on the tail. You should be able to move the nose wheel assembly by hand, but it should resist - not be too easy to move from side to side.
If you suspect a nose wheel shimmy (I can tell it by feeling it in the rudder pedals), raise the nose as mentioned above and see how easy it is to move by hand. Tighten it some, by the first method mentioned above, and then recheck to see if it is now harder to move. Then test fly to see if you have a fix. If not, then dissemble the nose wheel and sand some off the nylon blocks where they fit together as mentioned above.
Hope this helps.
Buz
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
N1BZRich(at)aol.com Guest
Posted: Mon May 31, 2010 7:49 pm Post subject: Nose wheel shimmy |
Reference my previous email on nose wheel shimmy. Scroll on down below the message for a photo of the nose wheel assembly.
Buz
In a message dated 5/31/2010 11:42:36 P.M. Eastern Daylight Time, N1BZRich(at)AOL.COM writes:
Hope this helps.
Buz
landjridge(at)775.net Guest
Posted: Mon May 31, 2010 9:05 pm Post subject: Nose wheel shimmy |
FamilyGage(at)aol.com Guest
Posted: Tue Jun 01, 2010 9:25 am Post subject: Nose wheel shimmy |
Buz:
Thanks, I plan to use your suggestion today.
My Best,
Ray Gage
In a message dated 5/31/2010 11:49:31 P.M. Eastern Daylight Time, N1BZRich(at)aol.com writes:
Quote: | Reference my previous email on nose wheel shimmy. Scroll on down below the message for a photo of the nose wheel assembly.
Buz
Hope this helps.
Buz
wampam
Posted: Tue Jun 01, 2010 9:56 am Post subject: Nose wheel shimmy |
I had/have a similar problem. I initially tightened the bolts on the block and reduced the tire pressure to about 25lbs. The shimmy got significantly worse. After loosening the bolts and leaving the tire pressure unchanged, the shimming was much less but still noticeable. However, I did not like the idea of having these bolts so loose. I then placed shims (barrowed an empty beer can from my hanger neighbor) between the blocks until I was able to move the wheel with about 10lbs of force and fully tighten the bolts. I hope to give this a try this weekend.
Walt M.
N881WP
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of FamilyGage(at)aol.com
Sent: Tuesday, June 01, 2010 10:24 AM
To: lightning-list(at)matronics.com
Subject: Re: Nose wheel shimmy
Buz:
My Best,
Ray Gage
Buz
Hope this helps.
Buz
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of this e-mail or any attachment is prohibited. If you have received this e-mail in error, please contact the sender and delete all copies.
Thank you for your cooperation.
n45bm(at)yahoo.com Guest
Posted: Tue Jun 01, 2010 12:24 pm Post subject: Nose wheel shimmy |
Is it possible that the entire nose wheel fork is vibrating or twisting, not just the wheel fork, causing wheel shimmy. Hope I'm not stirring the pot too hard. My 2 cents worth.
Bernardo
n45bm
--- On Tue, 6/1/10, Mefford, Walt <walt.mefford(at)garmin.com> wrote:
Quote: |
Subject: RE: Nose wheel shimmy
Date: Tuesday, June 1, 2010, 12:55 PM
Walt M.
N881WP
Subject: Re: Lightning-List: Nose wheel shimmy
Buz:
My Best,
Ray Gage
Buz
Hope this helps.
Buz
[img]cid:1.45459248(at)web82701.mail.mud.yahoo.com[/img]
FamilyGage(at)AOL.COM Guest
Posted: Tue Jun 01, 2010 12:39 pm Post subject: Nose wheel shimmy |
Thanks Walt:
Will attempt the fix from Buz tomorrow and see what his ideas may improve the situation. I will post should I have any luck.
My Best,
Ray Gage
In a message dated 6/1/2010 1:57:20 P.M. Eastern Daylight Time, walt.mefford(at)garmin.com writes:
wampam
Posted: Tue Jun 01, 2010 12:41 pm Post subject: Nose wheel shimmy |
I agree. This a very complex problem. Tire type, tire pressure, flexing of the fuselage, length of the landing gear and many other factors can contribute such as the runway surface and the friction between the tire. The factors can be different even for the same make and model of aircraft and one solution may not work for all. A difficult problem even today with commercial aircraft.
Walt M.
N881WP
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Bernard Melendez, Jr.
Sent: Tuesday, June 01, 2010 1:19 PM
Bernardo
n45bm
Walt M.
N881WP
Buz:
My Best,
Ray Gage
Buz
Hope this helps.
Buz
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
