IFLYSMODEL(at)AOL.COM Guest
Posted: Fri Jun 04, 2010 10:48 am Post subject: Wheel Balance |
Hey Bear: I guess I missed your message. How did the new type of tire balance work for you?
Lynn
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
n5pb(at)aol.com Guest
Posted: Mon Jun 07, 2010 8:13 am Post subject: Wheel Balance |
Lynn,
I put 1 ounce into the nose wheel and did 3 full takeoffs and landings with breaking and taxi back.
the shimmy I've experienced seem not to be there so I decided to put 1.5 ounces in each of the mains. When I got to the left main to remove the wheel, two of the 3 bolts that hold the wheel rimms together were missing and the 3rd one was just hanging in place. I was pretty stunned to see this (as you can imagine). The one remaining one looked as though it had been sheared off. I did a FOD walk around the local taxi area and found another piece of a bolt (this one still had the nut in place, but missing the head portion-appearing to be sheared off as well. Still haven't found the 3rd bolt.
As a result of this, I haven't proceeded with the install of the dyna beads in either of the mains yet. More to follow...
I would suggest everyone check their main rim bolts and nuts to make sure they are secure.
Bear
wampam
Posted: Mon Jun 07, 2010 8:45 am Post subject: Wheel Balance |
I did try dyna beads on the mains and really did not notice much of a difference. The biggest effect was by adjusting the tire pressure, tightening the axel nut so the drag on each main was approximately the same and going to 6 ply tires. This provided a noticeable improvement with tracking during taxi and an improvement in shimmy. It is still noticeable on rollout, however. Dyna bead effectiveness is related to tire diameter and rotation speed and 20 to 30 MPH seems to be where they are just starting to be effective with this size of tire.
Walt Mefford
N881WP
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of n5pb(at)aol.com
Sent: Monday, June 07, 2010 9:12 AM
To: lightning-list(at)matronics.com
Subject: Re: Wheel Balance
Lynn,
Bear
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
