Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Sat Jun 05, 2010 9:26 am Post subject: Engine Break In |
Well I managed to get the engine running well enough, and even though it was not idling well I went ahead with the break in procedure. (the equivalent of an hour long "root canal") Anyways, it seemed to run much better after the break in period but will still not idle.
Cheers
Ken
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
Fox5flyer Guest
Posted: Sat Jun 05, 2010 5:00 pm Post subject: Engine Break In |
Ken, my Model 2 with 582 was factory equipped with idle jets that were way
too rich that created a very rough idle. From ACS I reduced them by a
couple numbers (I don't remember what they were) that smoothed out the idle
significantly. No more problems.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 455+ TT
Previously Model 2 582 400 Hrs
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario
http://forums.matronics.com/viewtopic.php?p=300130#300130
Ken Potter
Posted: Sat Jun 05, 2010 6:03 pm Post subject: Re: Engine Break In |
Thanks Deke,
After a mind numbing hour of break in I'm now stepping back and educating myself about Bing carbs. I've owned British sports cars with dual carbs for 30 years, but the Bing carbs are designed with a different philosphy. I Have a copy of Mike Stratmans articles on the "Care and Feeding of the Rotax Motor" and plan to spend a rainy Sunday tomorrow reading it.
Interestingly enough, after shutting down the engine after break in, I gave the engine a shake to check the mounts and the forward carb started pissing fuel out the main jet again. I'm beginning to think it may be the primer that is funky.
Cheers
Ken
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
akflyer
Posted: Sun Jun 06, 2010 8:29 am Post subject: Re: Engine Break In |
if it is pissing fuel out the main jet after you shook the engine, it sounds like a float or needle valve problem. Make sure the floats are set per spec and there is no crap under the needle. If yours are viton tipped needles, they could have dried out after sitting for too long and wont seal right. Rebuild kits are cheap.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
