tc1917(at)bellsouth.net Guest
Posted: Wed Jun 09, 2010 2:45 am Post subject: sea foam |
I dont want to start a battle about sea foam but I have recently tried a sea
foam product call deep creep. It is a mult use penetrating lub. I have to
say, as a mechanic for about a hundred years, this is absolutely the best
stuff I have ever used. It has a spray distance of at least ten feet. Not
only penetrates stuck bolts but actually wicks into threads. It leaves a
good lubricant on the metal which seems to stay there. Used it on a stuck
slide out on a camper and wow, it really works. It is totally a petroleum
product. I also use three-in-one engine starter with a top end lub of three
in one oil in it. works great for small engines. My opinion. Ted Cowan,
Alabama, Slingshot, 912 zoom zoom
