coop85(at)bellsouth.net Guest
Posted: Tue Apr 25, 2006 4:10 pm Post subject: GPS Antenna location |
I know this has been addressed before, but I was wondering if any of you
that opted to put the GPS antenna under the cowling have any feedback, good
or bad, on the idea? I suspect reception is okay, my biggest concern is the
heat in that area affecting the not so cheap antenna.
Marcus
ron.mcgann(at)baesystems. Guest
Posted: Tue Apr 25, 2006 5:19 pm Post subject: GPS Antenna location |
I have checked the -10 archive and there is some confusing info there.
Both the Garmin and Comant antennas '. . . must be mounted on top of the aircraft . . . '[Comant ref and GNS430 Installation manual]. The Comant manual explicitly states a ground plane is NOT required. The GNS 430 does not say that a ground plane is required. The Comant reference http://www.comant.com/htmls/guide2.html even counsels against painting the antenna.
Why wouldn't the best place for a GPS antenna be on top of the cabin cover (just aft of the windshield)? The antenna cable could be fed down through the WD-1043 Centre Cabin Brace (which could also serve as a local ground point).
I have heard (rumour only) that GPS satellite coverage is not the best in the southern parts of Australia. Mounting the antenna under the cowl with airframe obscuration behind may further compromise performance. Mounting the antenna with the best view of the sky is the least risk option for me.
cheers,
Ron
187 fuse
Posted: Tue Apr 25, 2006 6:21 pm Post subject: GPS Antenna location |
Ron,
You make an excellent point about the antenna on top of the cabin. In fact, I’ve been testing out my 480 by just having the antenna out in the yard, clearly no ground plane, and it works fine. I think I’m going to at least try the “low drag” comm antenna from Van’s ($7, what could go wrong?) for my secondary radio so now I wonder if having the comm antenna near the GPS antenna could be an issue. Perhaps I’m making this too hard, but that’s half the fun I guess.
Marcus
40286
Tdawson(at)avidyne.com Guest
Posted: Tue Apr 25, 2006 7:03 pm Post subject: GPS Antenna location |
Can anyone explain why the "low drag" antenna shouldn't be called a "no drag" antenna?
TDT
40025
Tim(at)MyRV10.com Guest
Posted: Tue Apr 25, 2006 7:26 pm Post subject: GPS Antenna location |
Now you should know that Tim....The thing probably weighs a few ounces,
and every ounce of weight in the plane will cause just that much more
drag as the angle of attack needs to compensate to lift it. You'd
probably still lose at least .000000001 Kt of speed by adding that
antenna, don'tcha think?
Tim Dawson-Townsend wrote:
[quote] Can anyone explain why the "low drag" antenna shouldn't be called a "no drag" antenna?
TDT
40025
Posted: Tue Apr 25, 2006 7:31 pm Post subject: GPS Antenna location |
Okay, how about the "no parasitic drag and only a tiny bit of induced drag antenna"??
TDT
jesse(at)itecusa.org Guest
Posted: Tue Apr 25, 2006 7:32 pm Post subject: GPS Antenna location |
Is there any really good reason that it couldn't go on the upper forward
fuse skin right in front of the windshield and aft of the firewall? That
would not obstruct the pilot's view, and the cable would only need to be
about 18 inches or so. N256H has it on the glareshield inside the cabin
(avoids any problems with water getting in through a bad seal), and it works
great. Would it look terrible in front of the windshield?
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
JSMcGrew(at)aol.com Guest
Posted: Tue Apr 25, 2006 7:35 pm Post subject: GPS Antenna location |
I'm just throwing this out because no one else has mentioned it - I'm putting my GPS antennas on the glareshield. The antennas will certainly have a great view of the sky up through the plexi-glass, the install is easy and there is no concern about engine heat cooking them.
Jim McGrew
40134
In a message dated 4/25/2006 6:12:03 P.M. Mountain Daylight Time, coop85(at)bellsouth.net writes:
| Quote: | --> RV10-List message posted by: "Marcus Cooper" <coop85(at)bellsouth.net>
Marcus
Do not ========================== es Day
--> ================================================== - NEW MATRONICS LIST WIKI -
_-= sp; -> =========================p; - List Contribution Web Site ==================================================
Jim "Scooter" McGrew
jsmcgrew(at)aol.com
Posted: Tue Apr 25, 2006 7:39 pm Post subject: GPS Antenna location |
Where do you put your coffee cup, then? : )
TDT
40025, firewall forward
jjessen
Posted: Tue Apr 25, 2006 9:57 pm Post subject: GPS Antenna location |
In the Audi cup holder, which unfolds from the dash with a slight push of
the index finger.
dav1111(at)cox.net Guest
Posted: Wed Apr 26, 2006 1:19 am Post subject: GPS Antenna location |
I cut out two openings in the upper forward fuse skin. One on the left and
one on the right side of the center line. I then took some left over
fiberglass from cutting out the door windows and riveted it underneath the
skin holes and fiberglassed over the holes to create two openings of
fiberglass. Next, I installed a tray underneath each fiberglassed cut out
to mount the GPS antennas.
They look up directly through the fiberglass cutouts just as they would if
underneath the cowl or on top of the canopy. I hope to fly in the next
month so I will keep you posted on performance.
Russ Daves
#40044
rvbuilder(at)sausen.net Guest
Posted: Wed Apr 26, 2006 3:17 am Post subject: GPS Antenna location |
The reality is that GPS signals are basically immune to any type of fiberglass or plastic as long as it isn't covered with a metallic paint or anything else electrically conductive. Carbon fiber and metal will block most of the frequencies we deal with. Sure you will get some tiny amount of degradation from mounting it under glass but nothing worth mentioning usually. Lot's of people have made a little shelf just forward of the firewall to mount it on under the cowl and probably just as many have mounted it under their canopy. Both are as good of spots as mounting it on the exterior. If you do decide to mount on the exterior the drag will not amount to much, probably less than a knot depending on where you put it. It's more of a "clean look" type of decision. But if you are worried about it and on the fence, just mount it on the exterior as you can't go wrong.
As far as the engine cooking the antenna, most GPS (and XM/Sirius) antennas are amplified so there are some electronics in the antenna head. As with any other piece of electronic gear performance can suffer if it becomes too hot, just make sure it isn't mounted next to anything that radiates a bunch of heat like the exhaust headers.
Lastly GPS, and most satellite antennas we consumers deal with for that matter, are circularly polarized and do not require ground planes.
Hope that helps. I'm not an expert but I slept at a Holiday Inn Express last night.
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Tuesday, April 25, 2006 10:35 PM
Subject: Re: GPS Antenna location
Jim McGrew
40134
Marcus
--> ================================================== -> =========================p; - List Contribution Web Site ==================================================
jsmcgrew(at)aol.com
Posted: Wed Apr 26, 2006 3:49 am Post subject: GPS Antenna location |
One thing that turns me off about mounting it under a panel
somewhere (less of an issues perhaps than mounting it under
the cabin top, is that it could be harder to get a total
clear view of the sky in all directions. Imagine yourself
digging a 6' deep square hole in your yard, 8' x 8' wide.
Sure, you'll see some satellites, because a few of them are
high above the horizon. Will you see those that are low
on the horizon....well, at a certain point, no.
I'm not saying that it's crazy to mount the antenna elsewhere.
Certainly under the cowl will be better than under the
aluminum of the forward fuselage from the above scenario.
Everyone has their choice. The part that I find hard to
swallow when I think about doing this myself is that I
for the life of me can't figure out why anyone would
accept even the slightest degradation from mounting
location in a system that's designed to keep them locked
into a system that supposedly is to help them stay alive
by navigating to the runway through a cloud. If it
was a VFR install, I'd have much less concern.
Is "pretty good", or "fairly well", or "most of the time"
reliable enough for you?
RV Builder (Michael Sausen) wrote:
| Quote: | The reality is that GPS signals are basically immune to any type of
Express last night.
Michael Sausen
<http://www.mykitlog.com/display_project.php?project_id=22>
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*JSMcGrew(at)aol.com
*Sent:* Tuesday, April 25, 2006 10:35 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: GPS Antenna location
Jim McGrew
40134
feedback, good
concern is the
Marcus
jsmcgrew(at)aol.com
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Wed Apr 26, 2006 6:52 am Post subject: GPS Antenna location |
One trick to determine your field of view is to tape a long piece of string to the center of the antenna and hold it a various angles. If at any point one of those angles intersect something that blocks that view of the sky you have your answer on if it's a good spot. Short of mounting the antenna at the absolute highest point of your airframe, you will have some of the sky view blocked. In most cases it's almost nothing but in some locations it can be substantial.
Another thing to remember is those big sacs of water in the cabin (us) do a much better job at blocking many types of signals than the fiberglass or plastic. Keep that in mind as you decide where to put your antennas. In the same respect traveling below or around massive buildups (not someplace I would want to be anyway) would be much more effective at blocking your GPS than the fiberglass cabin lid. Either way if you are getting any amount of regular RAIM messages with modern GPS receivers you have a major installation problem in either the equipment or location. You can effectively block half of the sky view and you should still maintain a positive 3D lock almost the entire time with the possible exception of when sats are setting or rising over the horizon.
Michael
gorejr(at)bellsouth.net Guest
Posted: Wed Apr 26, 2006 8:43 am Post subject: GPS Antenna location |
That was slick. I thought the XM and GPS receivers could not be enclosed in metal. Thought they had to have a clear view of the sky. Thanks
Jim Gore RV-10
Georgia
Date: 2006/04/26 Wed AM 08:30:37 EDT
Gents ...
Check out Dan Checkoway's site on how he created removable glass panels between windshield and cowling area.
http://www.rvproject.com/hidden_antennas.html
Refer your questions to Dan ... dan(at)rvproject.com ...
Jerry Grimmonpre'
RV8A Electrical
glastar(at)gmx.net Guest
Posted: Wed Apr 26, 2006 9:04 am Post subject: GPS Antenna location |
My Garmin 196 with Antenna under the windshield had no issue in the
south of NSW, Victoria and South Australia.
Werner
McGANN, Ron wrote:
[quote] I have checked the -10 archive and there is some confusing info there.
cheers,
Ron
187 fuse
Posted: Wed Apr 26, 2006 9:59 am Post subject: GPS Antenna location |
They actually aren't. The top cover is fiberglass so their sky view is unimpeded for the most part.
dmasys(at)cox.net Guest
Posted: Wed Apr 26, 2006 3:50 pm Post subject: GPS Antenna location |
---- Marcus Cooper <coop85(at)bellsouth.net> wrote:
I have my GPS antenna under the cowl on my -7A, and connected to a GX-60. In 200 flight hours the GPS has never been anything but rock stable and available. It may be that whatever signal attenuation accrues to being beneath the cowl is offset by the fact that the cable run to the back of the GPS unit is only about 18 inches. In the SoCal RV group, there are at least 8 or 10 RVs configured this way and to my knowledge no one has ever reported and problems with the arrangement. Will do the same for the -10.
-Dan Masys
#40448
